False theft alarm
Old 06-27-2013, 03:59 AM
kaakshayakrishna
kaakshayakrishna's Avatar
Default False theft alarm
Hi,
I have a 1997 mustang which was imported to Dubai from Japan recently. It runs well but lately, it seems to have a problem. The vehicle is parked outside the apartment under the 50 degrees Dubai sun. Whenever I try to start the car in the afternoons or evenings, the theft warning signal goes off in the dashboard. This continues for a while and after several restarts, seems to work fine again. Anyone else facing this problem or have any thoughts? Do you think it is because of the extreme heat conditions here?
kaakshayakrishna is offline
Old 06-28-2013, 01:53 PM
darcane
darcane's Avatar
Originally Posted by kaakshayakrishna
Hi,
So, when you see the THEFT light, are you able to start the car? Or does "restart" mean you pull the key out and put it back in? Does the light flash? For how long?
Does it work better with the other key? (Do you have two?)
Do you have any trouble codes?
It could be an issue with the P.A.T.S. transceiver in the steering column. If it can't detect the key, it won't let the car start.
darcane is offline
JoshyGT
09-19-2017 08:52 PM
piotrek53
10-13-2015 06:54 PM
Beerman309
09-19-2015 01:16 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
JoshyGT
09-07-2015 02:04 PM
Quick Reply: False theft alarm
