High fuel press, erratic idle, begging for help!
Known symptoms:
80psi fuel press before car is started
Holds 80psi while erratic idle
Drops to 0psi ~10-15sec on shutdown
Air/fuel ratio at 10:1
Ignition timing normal
Things changed/cleaned
Changed spark plugs
Changed injectors
Changed fuel pump
Changed fuel filter
Changed o2 sensors
Changed intake manifold gasket
Cleaned maf sensor
Cleaned throttle body
Cleaned electrical connections
Things verified
Verified fuel press sensor ok
Verified spark plug wires ok
Verified coil pack ok
Verified proper/clean fuel
Possible thoughts:
Computer failure
Maybe vacuum issue
Any help is more than appreciated!
Changed spark plugs
Changed injectors
Changed fuel pump
Changed fuel filter
Changed o2 sensors
Cleaned maf sensor
Things verified
Possible thoughts:
Computer failure
Maybe vacuum issue
How did you verify the coil pack? A bad pack can test find on a multimeter. How did you verify the plug wires as well. They might have the proper resistance from one end to the other but if the rubber coating is breaking down at all there is a chance for them to arc to anything close. Had a thunderbird that they tested fine with a meter but two of them were still arcing on each other, changed them boom, car ran like new money. I bought that car for 400, replaced plug wires and flipped it for 1200.
That's not a good enough test for spark, just confirms that its getting A spark, could still be a weak spark. Might still be wires. But check what PNY suggested, the iac being out of wack even a hair can cause noticeable problems.
Fuel pressure shouldn't be that high. It is supposed to be 35-60psi. I personally only see it running 40psi anytime prior to this. Car "misfires" through the entire rpm range, wouldn't produce power, and is shooting black smoke out of both tailpipes.
Checked every connector, cleaned them out too just to make sure. New symptom though, my aeroforce gauge isnt reading batt voltage. I ordered a new ecm and its free due to warantee but i have a bad feeling its messing up and not functioning properly. It could explain the rich fuel mix but still baffled a out the 80-0 drop after shutdown.
