mustang not getting spark
Old 01-26-2015, 07:27 PM
fordman1699
fordman1699's Avatar
Default mustang not getting spark
I just did a v6 motor swap in my 94 mustang with an 01 v6 went to start it all ain't gettin no spark put a new coil pack on still nothin took the ignition control module in and apparently tested good put a new camshaft sensor on and swapped over the crank shaft sensor over off the old motor and switched over the computer and still aint gettin nothin can someone please help figure this issue out thank you
fordman1699 is offline
Old 01-28-2015, 02:25 PM
corker
corker's Avatar
I am not familiar with the differences in the '94 & '01 wiring harnesses, but maybe you have that worked out. In simple terms, the crank pos sensor(CPS) sends a signal to the Ign cntrl mod (ICM), the ICM sends a signal to the PCM (RPM signal) and the PCM returns a signal to the ICM to fire the coils. I don't have a wiring diagram, but there is a way to bypass the PCM and fire the coils with a test light to make sure the ICM and coils are functioning. Post a diagram of ignition wiring diagram if you have it and we can go from there. Also, a possibility of a security system issue in the middle of this.
Corky
corker is offline
Old 01-29-2015, 07:28 AM
fordman1699
Its hard to see any of the wiring that goes threw the ignition control system and I dont think its a security issue I dont have theft light on that I know a anyways
Old 01-30-2015, 11:22 AM
PNYXPRESS
PNYXPRESS's Avatar
Are you using the 01 keys or the 94 keys? the 01 is chipped and the computer might be looking for the key's signal before delivering spark. a regular nonchipped key will crank the motor over but not actually start it.
PNYXPRESS is offline
Old 01-30-2015, 02:59 PM
BabyGT
BabyGT's Avatar
The chipped keys are linked to the cluster and the computer i believe, so the best thing is going to be to run all the old computers.
BabyGT is offline
Old 01-31-2015, 10:42 AM
fordman1699
I been using everything from the doner car which was a 96 that they dropped it into so I have the 94 interior harness then have the 96 motor harness and plugged in the 96 computer perdy much everything plugged into the motor other then it didnt have a plug for what looks like a head temp sensor and another module that sits on top of the back a the block between the motor and the fire wall
Old 02-04-2015, 09:57 AM
BabyGT
BabyGT's Avatar
The........................
BabyGT is offline
ShaneB26154
35
03-04-2021 04:05 AM
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: mustang not getting spark
