Engine tick
Old 09-27-2015, 11:37 AM
Sixer4Life
Sixer4Life's Avatar
Default Engine tick
Alright I thought it was just the rockers but I got them all tightened down and I still have it. I only have it at higher rpm and when I let off the gas for a few seconds. I have no idea what else it could be. Any ideas?
Sixer4Life is offline
Old 10-09-2015, 09:08 PM
Sixer4Life
Sixer4Life's Avatar
Well 97 views and no opinions... ok. I'm pretty sure it's a lifter (not sure if it's just stuck or what) 2 questions.
1. Can I replace one set of lifters at a time or do I need to change all 12 at once?
2. Is there a way to replace my lifters without taking the head apart?
Old 10-10-2015, 08:08 AM
PNYXPRESS
PNYXPRESS's Avatar
Have you checked the exhaust system for holes, cracks, etc?
You don't have to disassemble the heads but you may have to remove them to get the lifters out.
I would replace them all if you are going to replace one. That way you know you actually replaced the bad one.
PNYXPRESS is offline
Old 10-10-2015, 08:17 AM
Sixer4Life
Sixer4Life's Avatar
No. Havent had anyone suggest that. I've tightened my rockers down already and it didn't help much so I didn't know if I should check lifters next or what. No one has ever said exhaust.
Old 10-10-2015, 03:22 PM
PNYXPRESS
PNYXPRESS's Avatar
Look closely at the p/s header. they are prone to cracking on the new edge cars.
Old 10-12-2015, 04:26 AM
Sixer4Life
Sixer4Life's Avatar
I think it is. I have a spot by the elbow on the passenger side right under my O2 sensor that is pitch black. Can't check if it's cracked or I have a bad gasket until I get it on a lift though. Can't get enough room to see it with just a floor jack.
Nick Oliver
10-17-2018 04:22 AM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Engine tick
