99 V6 Mustang loud squealing sound from engine
Old 12-09-2016, 06:43 PM
relentless85
relentless85's Avatar
Default 99 V6 Mustang loud squealing sound from engine
1999 Mustang 3.8L V6 Has a loud squealing sound coming from the engine. Sounds like it is coming from the front area of the engine. I replaced the water pump and power steering pump about 2 years ago thinking that was the issue but the squealing never really went away and is now getting worse.
I also thought it was one of the pulleys or tensioner, so I put a screw driver to my ear to each one of them but I don't think that is the issue.
I did some more research and found several posts about the cam position sensor might be wore out and causing the issue.
I have a video of what exactly the noise sounds like. It tends to do it more when it is cold out than warm.
Do you think this noise could be related to the CPS wearing out? The engine has 147K on it.
Video of squealing sound:
relentless85 is offline
Old 12-09-2016, 06:52 PM
Daehawk
Daehawk's Avatar
My first thought was belt but after seeing / hearing the video Im sticking to tensioner pulley.
Daehawk is offline
Old 12-09-2016, 06:58 PM
relentless85
I thought it was the pulley also, but put a long screw driver on the pulleys, and I didn't hear any high pitched noises or abnormal grinding coming from them. I especially thought it was the top pulley.
Old 12-10-2016, 10:25 AM
Stepman
Stepman's Avatar
pull the belt off and run it. If it still squeals, it's in the motor. If not, take a closer look at the pulleys...while the belt is off.
Stepman is offline
Old 12-10-2016, 10:29 AM
DRAGUL
DRAGUL's Avatar
Take the belt off and start the engine when cold, but only for a minute so as not to overheat the engine. If the noise goes away, then you'll know it is not coming from the engine but from one of the accessories. Did you replace the belt?
DRAGUL is offline
