07 Manual...Hard reverse?
Old 04-12-2007, 02:44 PM
DragonV6
DragonV6's Avatar
Default 07 Manual...Hard reverse?
I just got my mustang and i've noticed i have a really hard time getting into reverse. all other gears are fine, but reverse i have to play with for a few minutes to get it to drop sometimes....any ideas?
DragonV6 is offline
Old 04-12-2007, 02:50 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: 07 Manual...Hard reverse?
It's a Ford, it's a Mustang, they are ALL like that. If it's not currently it will eventually be like that.
Best way around it is, if it won't drop into reverse easily the first time, put it into first gear then try reverse. Sometimes you have to go First/Second then Reverse (takes all of a second to do). The other way is to slowly let the clutch out while pushing the stickinto reverse until it drops in. It will drop in before the clutch has a chance to engage.
Derf00 is offline
Old 04-12-2007, 02:51 PM
Margarita Girl
Is the tide gonna reach my chair?
Margarita Girl's Avatar
While you have the clutch in, put it in 3rd positon before you go down to reverse. This is a trick I learned for my '99 GT and it seems to line things up.
Margarita Girl is offline
Old 04-12-2007, 03:07 PM
8cd03gro
8cd03gro's Avatar
reverse is not synchronized so if you can't get into it, try letting the car roll back an inch or two, or if you can't roll back (you are on level ground) put it in first and roll forward an inch, then try reverse again. It's totally normal for that to happen and it will get easier as the cars wears in.
8cd03gro is offline
Old 04-12-2007, 03:13 PM
jerseystang07
jerseystang07's Avatar
ORIGINAL: 8cd03gro
+1...this is what I did when I first had mine
jerseystang07 is offline
Old 04-13-2007, 12:46 AM
harlanb1
harlanb1's Avatar
The owners manual talks about a kind of lock out that prevents you from accidently shifting into reverse.
If you move the shifter all the way to the left while in nuetral, and then shift it into reverse, it will usually go right in.
harlanb1 is offline
Old 04-13-2007, 07:22 PM
DragonV6
DragonV6's Avatar
Thanks for all the responses, the going to third first works really well.
DragonV6 is offline
Old 04-13-2007, 07:26 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: 8cd03gro
Not necessarily. I've had my car since day 1 (6 years now) and it still does it every once in a while. No more or less than when I first bought it.
Derf00 is offline
Old 04-13-2007, 07:36 PM
JochenHeiden
JochenHeiden's Avatar
It's hard on my '07 too, but the actually reverse gear catches much sooner on the clutch than any other. In fact, you don't even need to give the car any gas to move in reverse. I simply ride the clutch and gently ease it in and I can reverse without using the gas pedal. Works great and saves fuel!
JochenHeiden is offline
Old 04-14-2007, 12:43 AM
tilt
tilt's Avatar
sometimes first is a pain in the *** too, for that I go into second and with foot still on clutch into first like butter.
tilt is offline
Quick Reply: 07 Manual...Hard reverse?
