New Toys for the chase to 14.0's
Old 05-01-2007, 09:46 AM
merlinsrealm
merlinsrealm's Avatar
Default New Toys for the chase to 14.0's
Hey Everyone, I know I havent posted for a couple of weeks but wanted to give an update to those on the chase to 14.0's on bolt-on's...............
I have just picked up the following.........
3.73's rear end gears
7.5 trak lok
rear end gear install kit
BMR LCA's
I also am changing out the GT Takeoff's and doing a couple of other bolton's that have not been firmed up yet.
I have not been to the track yet this year because of work. I am constantly out of state, but should be able to get some shakedown passes when I get back in the month.
Eric
merlinsrealm is offline
Old 05-01-2007, 10:13 AM
MrSandman
MrSandman's Avatar
Default RE: New Toys for the chase to 14.0's
I thought that with a CAI and tune you could get into the 14s easy. I don't know it that's true.. but that's what i've heard.
MrSandman is offline
Old 05-01-2007, 10:25 AM
merlinsrealm
ORIGINAL: MrSandman
You are right but I am referring to 14.0 which has not been done yet.........
The 6 or 7 of us in the chase have gone anywhere from 14.3's to 14.6's
Eric
Old 05-01-2007, 12:21 PM
28HopUp
MF Administrator
28HopUp's Avatar
When I ran at CCD before adding the x-pipe, GT mid-pipe, and add'l GT take-off muffler, my better time of the two was 14.701 @ 95.7mph. This past weekend at Norwalk (after changing my exhaust set-up), my best time was 14.994 @ 93.71mph. Traction was an issue at Norwalk for me, and everyone seemed to run slower. But my speed was consistently lower at Norwalk after the new exhaust.
EDIT: I now know that my lower speed through the traps @ Norwalk was the result of track conditions and the driver, so adding duals should not have a negative effect on your ET's or speed.
28HopUp is offline
Old 05-01-2007, 12:44 PM
boss 244
boss 244's Avatar
28hopup-from what I hear the humidity was really bad there, that would of cost you a few tenths right there. Having 2 mufflers is a weight penality too. I would say it's the weather, not the car.
merlinstream-the closest time to 14.0 is now 14.13. You better hurry!
boss 244 is offline
Old 05-01-2007, 01:09 PM
merlinsrealm
ORIGINAL: 28HopUp
Hold off a week or so before adding the second GT take-off muffler. When I ran at CCD before adding the x-pipe, GT mid-pipe, and add'l GT take-off muffler, my better time of the two was 14.701 @ 95.7mph. This past weekend at Norwalk (after changing my exhaust set-up), my best time was 14.994 @ 93.71mph. Traction was an issue at Norwalk for me, and everyone seemed to run slower. But my speed was consistently lower at Norwalk after the new exhaust. Perhaps it was due to less back-pressure? The only way for me to know for sure is to duplicate the conditions at CCD and run there again to see if those times/speeds are affected.
I will certainly post my results...
I already have dual gt takeoff mufflersand custom H-pipe. I am changing out the gt mufflers for another brand.
Not usre why you ran so much slower. Weather, traction, + / - weight? also did you run the 14.7 time with the new gears?
Eric
Old 05-01-2007, 01:10 PM
merlinsrealm
ORIGINAL: boss 244
Oh Damn! Who ran that? I havent been paying attention!!!!!
Eric
Old 05-01-2007, 03:20 PM
rmays06
rmays06's Avatar
ORIGINAL: merlinsrealm
ORIGINAL: boss 244
Eric
14's aren't easy but doable with your mods. Most of the time CAI's and Tunes woun't get you there unless your a decent driver and everything is working right.
Boss ran a 14.3 and a 14.1, he is the N/A king now and probably forever. There are afew coming up but he has the crown. You should really be setting you goals a sub 13's in an N/A car. Good lukc and pratice you launches.
Norwalk was slightly Horrible, I was down 3mph and .3 in the 1/4. Not my best day.
rmays06 is offline
Old 05-01-2007, 04:12 PM
fitbikeco
fitbikeco's Avatar
ya no doubt norwalk was not as grand as i thought it would be as far as progressing times
14.0ss man theres not glory in 14.0
13.9 is where its at
fitbikeco is offline
Old 05-01-2007, 05:38 PM
28HopUp
MF Administrator
28HopUp's Avatar
ORIGINAL: rmays06
Ron, I didn't realize your speed was affected that much. That makes me feel better about my times and speed. I still wanna hit CCD to make a direct comparison of before & after on my duals.
ORIGINAL: boss 244
Boss, you're right about the weight of the add'lmuffler (and mid-pipe), but I had less weight in the gas tank at Norwalk. I had to stop making passes cuz I got down to "4 miles to empty".
28HopUp is offline
Quick Reply: New Toys for the chase to 14.0's
