Head and cam dyno numbers....(not mine)
Old 10-24-2007, 05:53 AM
rmays06
rmays06's Avatar
Default Head and cam dyno numbers....(not mine)
Hey Guys, on another site there is a guy who had Doug dyno his car with his head and cams done. I will print the post and link it although it will not go through due to site issues. But if you do a search for another 4.0 site you'll find it. It is from a guy who is running probably the most powerful X-charged car and took it off to get the head cam dyno. Doung was the guy dynoing the car. Well here you go.
well today Doug was out here on the west coast and I got to put my car on the dyno with him, many people have wondered what kind of numbers they might see with heads and cams, well today I found out what mine will do, the cam regrind was kept moderate when done back last winter but the heads were worked pretty good. my new numbers are 201rwhp/216rwtq. this is with the wiseco 8.8-1 pistons, cam regrind, head and valve work, headers, custom double "Y" exhaust with 12" glasspacks, stock injectors and airbox lid, Doug estimates probably another 20ish or so horsepower with some type of CAI, very interesting results to say the least, I am quite happy that I have these actual numbers, only wish I would have dynoed my car before I went crazy modding. LOL hope this helps clear up some questions for some, a more aggressive cam and higher compression ratio pistons would probably do more for a straight N/A car but mine was built for boost longevity.[/align]
[/align]
rmays06 is offline
Old 10-24-2007, 07:01 AM
banka87
banka87's Avatar
Default RE: Head and cam dyno numbers....(not mine)
That's some interesting info. I honestly expected more, but at least someone tried it haha
banka87 is offline
Old 10-24-2007, 07:59 AM
rmays06
rmays06's Avatar
ORIGINAL: banka87
If yoy look at it thou, 170 to 201 is not a bad jump 30HP for heads and cam work is a nice gain, plus this is without a CAI or other mod bolt on gainers. His car wasn't running up to snuff either.
rmays06 is offline
Old 10-24-2007, 08:09 AM
28HopUp
MF Administrator
28HopUp's Avatar
Good post Ron.
When I read your subject line, I figured it would only be a matter of time before a NA 4.0L car went with new cams and heads (either aftermarket or ported & polished). Then I realized it was a curious X-charger owner doing us all a favor by taking the time to dyno his motor in NA configuration.
No need commenting on the results - they are what they are (ie - not optimized for a NA set-up). I would love to go this route myself, but the cost per HP is relatively high, and I'm not sure that my car's daily driver status would be as enjoyable if the power band shifts up the rpm range. Conversely, I already have 4.10's, anda cammed 4.0L does sound mean. Where's my checkbook again???
28HopUp is offline
Old 10-24-2007, 08:11 AM
rmays06
rmays06's Avatar
The cost will remain high for a while and probably ever if Ford goes a differnt engine route with the Mustang in 2010. No one makes a blank cam and heads are not the easiest to fine. We are limited. Its great that someone did this and as Doug said if the car was running right with would have been more.....how much ?????
For right now that ain't bad.
rmays06 is offline
Old 10-24-2007, 09:09 AM
MrSandman
MrSandman's Avatar
That's about what my car did on a dynojet with my C&L and Doug's racing tune. It was 95 F that day too.
MrSandman is offline
Old 10-24-2007, 09:12 AM
Dwisforme05
Dwisforme05's Avatar
i too expected more but like ron said 170 to 201 is not abad jump at all. i mean if you can pull out 225rwhp and 245rwtq like it probably would with a CAI thats not too bad. how muc hdid the cams, and heads run him ron?
Dwisforme05 is offline
Old 10-24-2007, 10:14 AM
8cd03gro
8cd03gro's Avatar
you guys are missing the major thing here. This guy put down over 200rwhp with 8.8:1 CR pistons. Doug thinks there is another 20 in there with intake work, so let's say 215rwhp conservateively with 8.8:1 cr. 8.8 is very boost friendly but significantly lower than you want for n/a. Our stock pistons have a 9.7:1 CR which is a considerable difference. You could probably put down a good 10+ rwhp more with the stock pistons over the 8.8's n/a. This makes this information very good. 200rwhp n/a with the stock airbox and lower compression pistons could be good for >235rwhp with the stock pistons and a better intake.
edit: i just went and checked out the original post and noticed it's bscottie. So keep in mind here guys that this was an automatic car with a lower CR than stock, and cams that are better for a blown car. These are GREAT numbers imo. think about it this way-
201rwhp on an auto = 210ish rwhp on a manual + a solid 15+ with an intake, and im sure there is more left if he were to use a more n/a style cam. 235-240rwhp is doable.
8cd03gro is offline
Old 10-24-2007, 10:33 AM
banka87
banka87's Avatar
ORIGINAL: 8cd03gro
Hmph...As I think about it more in perspective, it makes a lot more sense. May be worth the cash down the road...
banka87 is offline
Old 10-24-2007, 11:16 AM
rmays06
rmays06's Avatar
Clay thanks, said much better than I could have. I truely believe that these are good if not great numbers. If tuned right and put togetherspecificly for an N/A car who know what you get and imagine the TQ numbers you could put down. Look past this HP number and see the potential here.
ORIGINAL: 8cd03gro
rmays06 is offline
Quick Reply: Head and cam dyno numbers....(not mine)
