Roush Scoop
Roush Scoop
I just want to see it on the v6 before I order it, heres the link to the setup I want. I'm getting it with the stripe if I buy it.
http://www.stage3motorsports.com/pro...tte_Black.html
Pics from the drivers seat would be well appreciated too.
P.S. Whats the difficulty level on the scoop install?
RE: Roush Scoop
i'm too lazy to go outside in the heat and take a pic from the drivers seat, hopefully these pics will help.
now that you have seen the pics, heres what i can tell you after driving 15k miles with the scoop.
1. if you drive over 70, you will see the front of the scoop start to raise up, like a 1/4 inch
2. if you have a stripe under the scoop, it will "bunch" up the stripe.
3. many have complained about "dimples" that apear in the scoop, ( i dont have any issues with this)
4. from the drivers seat, it looks mean as hell, add some exhaust, then your passengers will respect your car as a bad *** machine.
oh and the install isn't hard, just make sure you drill the holes right the first time. actually, if your scared about drilling the holes, just install it with the 3m two sided tape and if you dont like it after a year, just pull it off. I used the tape and screws in my install, shes there no matter what the speed.
RE: Roush Scoop
Here's a picture from the driver seat
The Roush install is really easy. It takes 7 screws, so you have to drill those holes, but the template from Roush makes that easy to get in the correct spot. Take the hood liner off, lay a blanket across the engine to catch the shavings.
RE: Roush Scoop
The scoop will not get "bunched up" by the stripe if you only stripe the top of it like in that picture.
I really like that look, though. If I were to redo the stripes on my car I'd probably do something more simple like that and just get a black or silver stripe like that on the hood and over the top of my scoop. It's much more effective I think on a V6.
RE: Roush Scoop
well i can only speak from experience from some one who had factory stripes on the car new. then adding a roush hood scoop on top of the stripes will cause them to bunch up. check around, and many will say them same. of course if you want to try your luck at cutting the stripe, you can always do that. or you can pay someone to custom make a stripe. either way, all im sayin is if you have a stripe under the scoop it will bunch.
of course , you will be fine if you buy a precut stripe that is with the kit.
RE: Roush Scoop
I've had mine for about 2 months, and love it. I haven't had any issues with it raising up at high speeds(I've been around 100 MPH). The only issue I've had is the bunching of stripes, but I've ordered some new stripes from BSM that are precut for the scoop.
I let a shop install mine for $25, and it took them less than an hour.
RE: Roush Scoop
ORIGINAL: jdphillips73
I've never seen my scoop rise up a quarter inch when going at fast speeds though... sounds like it might not be properly secure. 'Course I have the GT scoop, not the Roush.
RE: Roush Scoop
I'm not worried about the stripe because it is precut for the scoop, thats why I'm spending the extra cash on it vs a cheaper route (bsm super stripe).
I needed some reassurance on the install, I hate drilling through paint.
