07 Mustang V6, adding GT bumper and fog lights and HID, but have ?
Old 09-11-2009, 01:54 PM
ABQstang89
ABQstang89's Avatar
So is there a consensus on this? I'm looking into adding fogs to my base v6. So I would need to add a switch, relay, and fogs. And then just do the necessary wiring.
Sorry for the hijack
ABQstang89 is offline
Old 09-12-2009, 01:09 AM
asci01
asci01's Avatar
Just get a fog light wiring harness. It includes the relay, switch and all wiring needed. No need to mess with the "smart" box
http://musclecardirect.com/shop/prod...roducts_id=741
asci01 is offline
Old 09-12-2009, 09:54 AM
157dB
Cut & Paste Expert
157dB's Avatar
Get the GT headlight switch instead of drilling the
hole for the aftermarket toggle switch (yuck).
You will be glad you did in the long run and the
OEM fog light on reminder chime will be functional.
Necessary wiring:
Attached Thumbnails 07 Mustang V6, adding GT bumper and fog lights and HID, but have ?-headlight.jpg   07 Mustang V6, adding GT bumper and fog lights and HID, but have ?-img_2985.jpg   07 Mustang V6, adding GT bumper and fog lights and HID, but have ?-img_3014.jpg   07 Mustang V6, adding GT bumper and fog lights and HID, but have ?-img_3015.jpg
157dB is offline
Old 09-13-2009, 07:59 PM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
Originally Posted by tx_zstang
+1. Unless you have a Pony Package with fogs already, you wont have what you need for foglights. The extent of the wiring is, there is a location in the underhood fuse box for a relay and fuse, and there are wires run to the headlight switch and SMJ.
A GT headlight switch is a great way to do the switching, but that just provides a ground to the SMJ which is supposed to energize the relay, assuming the relay is in; but most likely, the SMJ is not configured as such and won't ground the relay pin that it is supposed to.
And then there's the need to run the wiring to the lights themselves.
I dont know what wiring kits are available, but I simply got the headlamp connectors and ran the needed wires, tying into the underhood relay/fuse center at the appropriate relay output. And I cheated on the SMJ signal/ground wire, bypassing the SMJ and routing the wire direct to the headlight switch.
It works just like in a GT now, pull out the switch when the parking lights are on, and the fogs come on.
Mike, you may have to take a trip to Houston and help me install my switch then
ODDYSEY is offline
Old 09-13-2009, 09:53 PM
JCON
JCON's Avatar
Originally Posted by 157db
if Your V6 didnt have fogs, there are NO pigtails tucked up anywhere.
You must add a relay and a switch (GT headlight Switch preferred...)
If you are truly gonna do this, I have the schematics of how I did it.
eBay sells the harness and the headlight switch....
Could you send these to jcon@udel.edu please?
JCON is offline
Old 09-13-2009, 09:57 PM
JCON
JCON's Avatar
**unless the pics you posted were the full resolution anyways**
Also can the wiring harness be used with OEM fog switch?
JCON is offline
Old 10-04-2009, 01:05 PM
leesha12
leesha12's Avatar
I have an 06 v6 mustang, i would really like to add the additional two fog lights in the front like the gt's.
unfortionanly i don't know what i need or anything to make this possible..
anyone willing to help me..please?
leesha12 is offline
Old 10-04-2009, 10:13 PM
discodave
discodave's Avatar
Do you have fog lights at all already on your car? If so, you can just tap into the existing fog light wiring (piggyback) with the GT style fog lights once you get them in.
discodave is offline
Old 10-05-2009, 11:15 AM
157dB
Cut & Paste Expert
157dB's Avatar
Yes, the relay must be converted from sourcing to sinking for the coil.
(The GT headlight sinks the output instead of sourcing it.)
It depends on whick aftermarket fog light harness you get.
They are available on eBay that includes the GT headlight switch
and is properly wired for it AND the fog light indicator (dont forget that...).
I did it and it was super simple. (for me)
157dB is offline
Old 04-29-2010, 08:15 AM
texasbrit
texasbrit's Avatar
Necessary wiring:
Sorry to drag up an old thread as my first post, but for some reason I'm not able to access these pictures.
I installed a new foglight grill last night using the StreetScene wiring harness and I also bought a GT switch. All went well until it came to wiring the harness into the switch. I don't want the toggle switch supplied with the harness so how can I wire the harness into the GT switch to make it work as described in this thread?
Currently I have the toggle switch which has a yellow wire connected and a red which I would tap into the red/white wire if I was to complete it the way the instructions say with the toggle. If I disconnect the yellow and throw the toggle away, where would I connect the yellow wire to be able to use with the pull-out GT fog switch?
Thanks in advance for any help you can offer.
Paul
texasbrit is offline
Quick Reply: 07 Mustang V6, adding GT bumper and fog lights and HID, but have ?
