Had an interesting experience with 91 octane
Old 03-19-2010, 11:47 PM
THEBLACKSTANG
THEBLACKSTANG's Avatar
Default Had an interesting experience with 91 octane
I decided to put 91 octane in the last time I filled up and I've noticed a fairly large difference in how smooth the engine runs. Is this normal? The previous owner installed a S&B intake (no tune required) and at first I thought that maybe they had gotten a tune and I was running the wrong octane. There are no check engine lights on the dash, and I would be having some serious issues if I was running the wrong octane right? Sorry for the newb question.
THEBLACKSTANG is offline
Old 03-20-2010, 07:47 AM
Moderator
JimC's Avatar
Running higher octane than the car is tuned for won't give you serious issues with the car.
It is probably running smoother because your wallet is so much lighter though.
JimC is offline
Old 03-20-2010, 08:32 AM
157dB
Cut & Paste Expert
157dB's Avatar
Higher Octaines without the proper timing
adjustments is just $$ thrown down the drain.
157dB is offline
Old 03-20-2010, 08:44 AM
Nuke
Nuke's Avatar
Have you ever noticced how much better your car runs after you wash it, too?
I'm sure you believe that you felt a difference and maybe you really did. But I wouldn't jump to the conclusion that higher octane is what did it. It may be possible that the 87 octane you had was inferior.
Higher octane fuel than what you're tuned for supposedly has no positive impact with the exception of those S197's with the Bullitt tune (NO V6's) where the PCM can make minor timing corrections. Some have even claimed that chronic use of higher octane can cause issues (besides poverty) but for the life of me I can't recall what those are.
Keep experimenting and researching. The choice is yours but you'll find the concensus tell you that you ARE wasting your hard-earned cash.
Nuke is offline
Old 03-20-2010, 09:21 AM
157dB
Cut & Paste Expert
157dB's Avatar
The only thing the 91 has going for it is the additional additives
that 87 does not have. Maybe it will clean your injectors that
have had 89 run thru them for so long....
157dB is offline
Old 03-20-2010, 09:42 AM
Nuke
Nuke's Avatar
And, BTW, running a higher octane than what you're tuned for will NOT cause you to throw a CEL/code. If you were tuned for a higher octane and were using a lower octane, you STILL wouldn't throw a CEL but you'd hear the engine pinging/knocking under most any load.
Nuke is offline
Old 03-20-2010, 09:52 AM
157dB
Cut & Paste Expert
157dB's Avatar
Then the knock sensor takes over and the timing is pulled back
to prevent knocking and the power goes out the window persay...
157dB is offline
Old 03-20-2010, 11:27 AM
THEBLACKSTANG
This was my main concern, and I didn't want to do any damage to my engine. I know that without a tune I wasn't going to see any gains, which was why I thought this was weird.
and yes nuke, my car runs much better after a wash lol
baddog671
07-26-2016 01:20 PM
BeatnikFink
10-01-2015 08:00 PM
mdg
10-01-2015 07:04 AM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Had an interesting experience with 91 octane
