Tire pressure sensor
Old 09-29-2010, 05:52 PM
Mirky87
Mirky87's Avatar
Default Tire pressure sensor
Just purchased an 08 Stang. The tire pressure sensor went off on the second day we had it. Checked the tires and they were set at 31 psi, while the tire recommendation is 44 psi. Filled them up to specs and the light went off. Three days later the sensor went off again. Checked the tires and one was down by 3 psi. So here's my question. Are the sensors that sensitive?
Thanks
Mirky87 is offline
Old 09-29-2010, 06:39 PM
Nuke
Nuke's Avatar
Check the Owners Manual and the drivers door jamb placard. The recommended pressure is around 30 PSI and most folks rarely run higher than 34 PSI. The 44 PSI you're referring to is what's on the tire sidewall and is the MAXIMUM manufacturer's pressure and NOT what you should have the tires at. The TPMS sensors are set to about 26 PSI. Have you checked your spare?
Nuke is offline
Old 09-29-2010, 08:37 PM
shnorse
shnorse's Avatar
the spare has the tpms also? didnt know that
shnorse is offline
Old 09-29-2010, 10:03 PM
MOOK3456
MOOK3456's Avatar
lol the wife did that with her car. Had it up to 50psi and couldn't understand why I was acting like she was crazy.
MOOK3456 is offline
Old 09-30-2010, 08:14 AM
Nuke
Nuke's Avatar
To be totally honest, I'm not sure about the spare in the Stang. I know the spare on my 4Runner has the TPMS sensor.
Nuke is offline
Old 09-30-2010, 10:30 AM
157dB
Cut & Paste Expert
157dB's Avatar
According to the Ford Workshop Manual for the 07,
there is NO TPMS sensor in the spare tire....
The pressure on the sidewall of the tire is the MAXIMUM
pressure for that particular tire at MAXIMUM load limit
for same said tire.
Less load like the stang means less pressure for it to be
properly inflated for good tire wear and gas mileage...
Read the door sticker like 100% of auto now have for
the proper recommended tire pressures.
HERE is how to properly diagnose TPMS problems...
157dB is offline
Old 10-03-2010, 01:02 PM
Mirky87
Mirky87's Avatar
I would like to thank all for the help. The problem has yet to be resolved, thus she will be going into the shop.....
Mirky87 is offline
Old 10-03-2010, 07:04 PM
Tamorand
Tamorand's Avatar
Are the tires stock or upgrades?
I believe you have to reset the sensor after upgrading the tires ( I had to) and they can act squirelly* until you do.
I watched the guys at my shop do it with brake down, and cycle the ignition on and off but the actual sequence escapes me.
Tamorand is offline
Old 10-04-2010, 07:12 AM
Mirky87
Mirky87's Avatar
Default Stock Tires
I believe the tires are stock. We purchased the car from a Ford Dealer two weeks ago......
Mirky87 is offline
Old 10-04-2010, 10:18 AM
157dB
Cut & Paste Expert
157dB's Avatar
And they have the correct TPMS sensors in there??
Go back to the Ford dealer and complain.
Squeeky wheel gets the grease....
157dB is offline
Quick Reply: Tire pressure sensor
