upper control arm bushing
hey so i just got a takeoff rear end, but it did not come with an upper control arm bushing. is it worth it to upgrade the bushing to a poly urethane one? or is there not much reason too. also, anyone know the part number for a stock one bc i called a dealership and they didnt seem to know what i was talking about
I have a rod end bushing in mine, kinda wish I had a poly because of the noise transfer of the rod end, I would just say order a poly bushing and call it quits. You will probably be looking around 10 - 15 for a rubber bushing anyhow.
http://www.newfordparts.com/ifrm_browse.php
I forgot to tell you about that bushing. We just removed it from my old rear end and inserted it in the new one. But there are upgrades out there and I keep thinking I should have upgraded.
Here is one from Steeda for example
http://www.steeda.com/store/steeda-u...shing-kit.html
I know that there are others but can't find the links I saved now.
http://iihs.net/fsm/?dir=65&viewfile...rm Bushing.pdf
I vote POLY on everything.
Rubber OEM anything sork badly.
