05-09 GT suspension on 2012 V6?
I'm looking to upgrade this lackluster stock 2012 V6 base suspension. Does the 05-09 GT suspension fit on the later S197 cars? I found a set on newtakeoff.com from the previous GTs and was curious if it's a direct fit.
http://www.newtakeoff.com/mustang_gt...2005-2008.aspx
It will fit I'm sure but I don't think it is an upgrade. I thought the 2012 had several suspension upgrades compared to prior years? And since it is set up for the heavier engine up front you will see the front riding higher - at least that has happened when 2005-2009 cars have put the GT springs up front -
research what lack lust you have under there now.
Visit the dealer with some calipers and
do some sway bar measurements comparing
the 2011-12 to the 05-10 GT suspension parts.
05-10 Rear GT sway = 20mm
05-10 Front GT sway = 34mm.
See what you have now or look for the 2012 mustang
specs and compare them to the 05-10 specs.
The mounting points are the same.
It just might not be an 'upgrade' to do so.
I would not bother with the 05-10 Gt springs on your 2012 V6.
Matt's 95 Stang
10-05-2015 07:16 AM
