Duals on 4.0
Duals on 4.0
Been considering getting duals from the cats to the tips no h-pipe or x pipes or anything and was just wondering if anyone had done it and whether it would be a good idea or not, not expecting alot as far as performance goes as my car is NA and is a v6 so not a big need for a free flowing exhaust but was more wondering about the sound and any negatives...
Thanks
Thanks
Originally I was just thinking of getting duals, I had no clue about any other part of the exhaust. I was actually gonna just go for the MAC duals http://www.americanmuscle.com/mac-du...st-0509v6.html which is a completely plug 'n play with no cutting(except for bumper) as it bolts right up to the stock Y pipe.
I was talking to a guy who had the MAC dual and he said there was a nice sounding drone for the first few thousand miles but that after they broke in it was just a nice rumble with no drone. He had them for like 5 years or something so I think it's a good choice if you're not wanting to redo your exhaust from head to toe.
Personally I'm getting LT headers, catted shorty H pipe, and an american thunder catback.
Hope I helped a little.
Thanks
Thanks
Arkansas V6,
Seems like the MAC Dual Exhaust Conversion kit is exactly what you're looking for. It's perfect for anyone who just wanted to bolt-on a dual muffler system and not having to bend or weld piping.
Let me know if there's anything else I can help you with!
Shane
Thanks for the responses but i am looking at elimintaing any restriction. Im tallking about where each header after the cat has its own pipe goin to its own tip out the back. Which makes two pipes individual of eachother that in no way connect to each other
Thanks
Thanks
I'll keep an eye out though.
Our cars have a pretty breathable exhaust stock but duals will SLIGHTLY increase performance. As for ghe no back pressure ideA. Remember all cars need some back pressure or you will have some unpleasant problems
I had true dual with flowmaster super 40's and it sounded poor and had alot of back fireing when decelerateing and i didnt see much performance increase, then i made up a h pipe for it and it sounds better and the back pressure is more equal and made more power with less backfire. Note my cats were intact for these findings the back pressure from tru dual i found to be a issue if you run a x or h pipe it will be alot better. Im a mechanic for a living and did tests useing the ford ids and a emissions sniffer
When I did mine, I used a pypes off-road h-pipe that I got for cheap, cut about 3-4" back from the cat's(I pulled the cats and had the opening expanded out to 2.5"). Cut the h-pipe to the correct length and bolted it up. From there it's pretty explanatory.
JDWalton
09-24-2015 08:47 PM
