Requesting suggestions for project build...
Old 06-03-2015, 07:27 AM
  #21
JJHoover
JJHoover's Avatar
Originally Posted by azdriveshaft
We also offer a direct bolt in shaft! it is made from .120 wall tubing and uses 1350 series U-joint's (which is both larger joints and thicker wall tubing than the aforementioned shaft above) Our direct bolt on flange to the rear pinion yoke is a billet aluminum C&C'd piece that we have custom made for us instead of the normal cast flange that is commonly used. give us a call at 480-898-1957 if there is anything we can do to help with your build.
how much do you charge for your drive shafts?
JJHoover is offline
Old 06-03-2015, 06:18 PM
  #22
azdriveshaft
Former Sponsor
azdriveshaft's Avatar
Our Driveshaft is priced at $750.00 retail, If you call and mention the forum you can get 10% off!
azdriveshaft is offline
4cylinderplus2
10-09-2020 07:45 PM
Matt's 95 Stang
10-05-2015 07:16 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
Suree_Mustang_2009
09-25-2015 12:58 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Requesting suggestions for project build...
