17X9 Fox guys
Old 04-11-2011, 10:29 PM
Topless89GT
Topless89GT's Avatar
Fox 4 lug, 17 x 9 Cobra R
Likely has,
+18 mm offset
5.71" backspace
Tires, 245/45/17 - should work fine.
That is if there hasn't been any suspension mods, lug conversions or spacers in there.
Topless89GT is offline
Old 04-11-2011, 10:45 PM
318's Avatar
I haven't checked into any suspension or spacers. I'll hopefully be able to get to that tomorrow. As well as get some pics of the tire damage.
318 is offline
Old 04-12-2011, 07:23 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Spacers can be a tricky thing and especially up front
I run a set of 1/2" out back, but had proved clearance for them prior to the installation and had new longer racing studs machined to replace the OEM ones. Up front, issues of scrub radius come into play and you already have damage to the outside of your tires. Spacers, if you are considering them, would only make this issue worse. Not to mention, that your studs might not be long enough to accomodate them and they would need to be replaced.
Not sure if you are thinking about them up front, but just to let you know
Jazzer
Jazzer The Cat is offline
Old 04-12-2011, 11:44 AM
Timspony
SVT Section Moderator
Timspony's Avatar
245's up front
275's out back .... NO spacers
Timspony is offline
Old 04-12-2011, 04:10 PM
318's Avatar
What kind of offset?
318 is offline
Old 04-12-2011, 04:45 PM
Timspony
Timspony's Avatar
Backspacing 5.94" .... O/S +24mm ... FRPP '95 Cobra R's
Timspony is offline
Old 04-12-2011, 06:28 PM
318's Avatar
Thanks.
318 is offline
Old 04-13-2011, 06:02 PM
318's Avatar
Let me know if you need another. I was outside and remembered this thread so I grabbed one with my phone.
318 is offline
Old 04-13-2011, 08:57 PM
Jazzer The Cat
Retired Moderator
Sure looks like a bit of fender rolling would be your best friend here. Look up under the fender and find the rubber stains on it. If it is only in an area or two, just look into carefully bending those areas out of the way. If it is rubber marked all the way around, this is more involved and may consider going a bit narrower a tire instead. Exactly how much narrower to clear, may be hard to tell. I would start by going 40 series up front.
Jazzer
Old 04-14-2011, 02:36 PM
89LX5pointO
89LX5pointO's Avatar
They are regular Cobra R's right? I have 17x8F and 17x9R Deep Dish staggered Cobra R's but don't think my info will help you at all...
89LX5pointO is offline
Quick Reply: 17X9 Fox guys
