How to tell OEM from Replica 93 Cobra wheels?
Old 01-11-2007, 10:24 AM
mac_24_seven
mac_24_seven's Avatar
Default How to tell OEM from Replica 93 Cobra wheels?
Hey
I've got the opportunity to buy some Original 1993 Cobra wheels for.........
$150.00
It's a stupid good deal. The guy says he's in a bind and that the wheels came off his last Cobra.
What markings'/casting are on the OEM wheels? I want to be able ti identify them and make sure I'm not buyin replica's. Even if they are replica's, $150.00 is still a sweet deal... But if they truley are the real deal... Oh my
Thanks
mac_24_seven is offline
Old 01-13-2007, 10:31 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: How to tell OEM from Replica 93 Cobra wheels?
there should be a ford part number on the back and the first two digits will be F3
AdderMk2 is offline
Old 01-15-2007, 12:17 AM
tricyclerob
tricyclerob's Avatar
Hi, I have the wheels off of my 93 cobra[bought new] and the wheels are marked "RH" and "LH". The "RH" wheel has a raised casting under the area where the hubcap goes, in between 2 of the lug holes. This raised number is "F3ZC-10007-AA" for the RH wheel, and "F3ZC-10007-BA" for the left wheel. Also there is a raised casting with "17x7.5". On the inside of the wheel the LH wheel has a raised area with number"101692 2". The RH wheel has number in sm area with # "101592 2". Also on the inside is a "Ford oval" about 1 inch long. There are other id marks on the inside including a small triangle, and2additional raised areas w/a stamped number, that might be diff. on each wheel. Hope this helps. rj
tricyclerob is offline
5.0muscle
01-11-2016 01:17 PM
11-10-2015 11:39 AM
robcy
Suspension
10-27-2015 11:14 PM
TfcCDR
09-12-2015 04:13 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: How to tell OEM from Replica 93 Cobra wheels?
