Fox body fr500 18x10
Hey guys just bought my 1st fox body... I am starting with a few brake and suspension upgrades I bought some cobra 13 inch rotors sn-95 spindles the wheels I am using are fr500 18x9 up front and 18x10 in the rear.... Now I am looking in to buy 5 lug rear conversion... I am not sure what axles to use range axles to keep the same width in the rear or should I go with sn-95 to push them away from the inner wheel well.... I don't want them to stick out pass the fender well (with sn-95 axles) or rub the inner (with range axles)....
I have a chance to get a sn-95 complete rear.... Any advice would work..?? Thanks
Style: FR500
Finish: Black
Centercap Size: Large (2-1/2")
Back Spacing: 6.3" (161mm)
Offset: +22mm (0.9")
Bolt Pattern: 5x4.5" (5x114.3mm)
Fitment: 94-04 V6, GT, Bullitt,
Mach 1, and Cobra
Style: FR500
Finish: Black
Mach 1, and Cobra
Take a look at:
10" wheels on a Fox Body
You are pretty much limited to a 275 tire, but will fit nicely on a 10" wheel. You will be VERY tight back there, on this width, so you need to do your homework well.
BTW... you are doing brakes and suspension, take a peek at my sig and have some guides to help you with both
Jazzer
Jazzer
