Tire Size on 17"
Old 03-09-2012, 08:54 AM
Rockford_Vzla
Rockford_Vzla's Avatar
Default Tire Size on 17"
When i bought this car he came with this Maxxis Victra MA-Z1 tires 255/40R17 on the 4 wheels, but i'm thinking to change the rears for something like 275/40 or 295/35, but i have two questions:
1.- The Wheel are enough wide so that the tire fit perfectly?
2.- The Wheel Clearance, could hit the rear fender?
this is the wheels picture
Rockford_Vzla is offline
Old 03-09-2012, 12:14 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
That is an 8" wheel and should have no more than a 245 installed. Even the 255's current, are too large for a proper fit. You can certainly run a much wider tire and avoid rubbing issues, but you need a wider wheel to do so. You can easily run a set of 9" (f) and 10.5" (r) without issues.
Jazzer
Jazzer The Cat is offline
Old 03-09-2012, 02:27 PM
Dub's
Dub's's Avatar
Yes 255 is the max and 245 is staying on the safe side.
Dub's is offline
Old 03-09-2012, 02:46 PM
Rockford_Vzla
damn, thanks for your answers
Old 03-09-2012, 07:40 PM
Jazzer The Cat
Retired Moderator
245's are max, 255's are too wide Now, this is not a real big deal, but leads to a bit sloppy cornering and less than ideal tire wear.
Jazzer
Old 03-10-2012, 03:47 AM
Dub's
Dub's's Avatar
Indeed cornering will be sloppy and heavy. He might just use it for just highway pulls. lol
Dub's is offline
Old 03-17-2012, 06:58 PM
Js88lx
Js88lx's Avatar
No offense to all you guys that have more knowledge on the subject but i can say that iv ran 275's on STOCK 87-93 ponies with no problem at all! Of course im not racing around the track.., just street use!
Js88lx is offline
Old 03-17-2012, 07:02 PM
Jazzer The Cat
Retired Moderator
I realize that MANY do exactly this, but still a bad idea
The issue becomes one of strain on the sidewalls and bead seal. Poor tire wear and improper contact patch. Such a tire will be sloppy in the corners, when pushed hard and will lead to less stabilty at higher speeds.
Jazzer
2007CalSpec
09-09-2015 05:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Tire Size on 17"
