Grill Replacement
I just bought the fog lights/grill without wiring harness or switch. Where did you end up buying your harness and switch? How much did you pay? If you usedaftermarket, how exactly did you connect the wires? It looks like it's tough fishing wires to the inside compartment. If you used an aftermarket switch, did you remove the plastic cover underneath the steering column to drill holes and attach the switch? I'm considering using an aftermarket switch and just use 3M double-sided tape.
Thanks in advance for your help
stangster1
stangster1
I was considering the one from Blue Oval until I saw the street scene Eleanor style kit - much cooler looking kit for the price. I have to agree with some of the other comments that rather than making the V6 a GT wannabee, why not make it a little more unique?
ORIGINAL: MarkTexAF
When I bought it I knew I wasn't getting the wiring/harness. I plan to get that later on. I just need to know if anyone has installed one of these before and if it was a correct fit.
