I installed the Sequential lights
Old Mar 6, 2007 | 05:12 PM
  #31
LisaJ429's Avatar
LisaJ429
Default RE: I installed the Sequential lights
i have the cdc sequentials alsoand love them. my husband had to actually follow me and he said they look awesome when you are behind.we installed them and there was no sodering, etc. unplugged original and replaced the sequential set. took no more than 10 minutes.
Old Mar 6, 2007 | 10:50 PM
  #32
Rupp's Avatar
Rupp
Do you have to remove the tail light assembly to install these?
Old Mar 6, 2007 | 11:04 PM
  #33
Rupp's Avatar
Rupp
Guys I thought I read where the OEM plug was changed in mid '05 but Web Electric doesn't show ( at lease not where I saw) different wiring harnesses.
Old Mar 6, 2007 | 11:35 PM
  #34
rls82959's Avatar
rls82959
ORIGINAL: Rupp
Yes, remove plastic trim inside of trunk.
Remove taillight housings.
Remove harnesses.
Put bulbs in new harnesses.
Mine are CDC for 06-07 Stangs. Yes, the plugs changed. Check out CDC website.
Took me about an hour.
Old Mar 7, 2007 | 12:27 PM
  #35
SOHCman's Avatar
SOHCman
ORIGINAL: rls82959
ORIGINAL: Rupp
Remove harnesses.
How did you run the control wire to the "turn signal power"? Or is the CDC setup different than the webelectricproducts setup?
I am really likin' these.
SOHC
Old Mar 7, 2007 | 02:15 PM
  #36
LisaJ429's Avatar
LisaJ429
ORIGINAL: SOHCman
ORIGINAL: rls82959
ORIGINAL: Rupp
Remove harnesses.
SOHC
the CDC plugs back into the factory harness.
Old Mar 8, 2007 | 01:58 PM
  #37
Professor Wizard's Avatar
Professor Wizard
MF Moderator
I went with the Chasers from www.meter4it.com.
They weren't very hard to install, and you can choose from non-sequence, standard Sequence or Chase Sequence.
These also sequence when you hit the brake, and use your flashers.
And, I'll tell you what - with the addition of the third light working on brake/turn, it makes your tail lights BRIGHT AS HELL when you hit the brakes or sigs!
Here is a link to their product.
http://www.meter4it.com/2006_and_2007_Mustang.htm
Later'
Old Mar 14, 2007 | 12:53 AM
  #38
atom21's Avatar
atom21
Wow! Where on earth did you buy them?
__________________
Mustang 07 - Ford Mustang Catalog 2007
Old Mar 14, 2007 | 07:15 PM
  #39
Rupp's Avatar
Rupp
ORIGINAL: atom21
There are 2 links in his post?
Old Mar 14, 2007 | 07:42 PM
  #40
edgespeeder06's Avatar
edgespeeder06
http://www.meter4it.com./2005_Mustang.htm seems really cool but i dunno, messing with wires isnt my thing, why cant u have it in a harness like the squential kits, is it hard?
