My door handle sticks
Hi Ya'll.....
I need some help from you guys on my 2005 GT. My exterior drivers side door handlewill not close completely. The handle is slightly extended and will not seat flush unless pushed in. I'vetried spraying lubricant which helped a little but I'm suspecting I might have a larger problem. Have any of you guys experienced this problem? Please HELP before I take it to the stealership.
Oh, mileage on my 2005 is 58K. And one more thing, my granddaddy has a Model T and the door handles still work! What gives?
Ms. Stang
Ms. Stang
RE: My door handle sticks
I've read that it's a common problem with the handles. My passenger side does it but I have been too lazy to have the dealership fix it. I better have that fixed along with the emblem on the steering wheel before my warranty runs out.
I assume the '07's are the same design as the '05's because, when I bought mine, the salesman told me to be careful not to yank really hard on the handles. Part of the mechanism apparently deforms.
Rick
[sm=smiley34.gif]
Rick
[sm=smiley34.gif]
I had the same problem on my old 05. The handle would get stuck like 1/8" out. I ended up having to have them replace it under warrantee. My dads buddy is a mechanic at the dealership that did that work so I did the replacement with him and it turned out that the spring inside the handle had just lost its springyness by a tiny bit.. You can order the replacement from ford parts if you aren't covered, I dont remember how much it was. Taking the door apart was easy though, all total it was maybe an hour job.
ORIGINAL: Boozshey
I was about to post the same thing for my 05. Im so pissed cause I am 2000 miles out of Warranty!!! SUCH BS!!!
-- Roger
