45mm offset with 9.5's in front will it work?
Old Feb 26, 2009 | 03:08 PM
Slowburn's Avatar
Slowburn
Default 45mm offset with 9.5's in front will it work?
I'm looking at some 20's with a 45mm offset that are 9.5" wide. Will I run into problems turning or rubbing after a 1 to 1.5" drop? I would like to run a 255/40/20 if it will fit
Old Feb 26, 2009 | 03:13 PM
pascal's Avatar
pascal
S197 Section Modder-ator
It might fit.
That tire is too skinny for 9.5 though...
Old Feb 26, 2009 | 03:15 PM
Stang-aholic's Avatar
Stang-aholic
Its either gonna be REALLY close or you r gonna rub all the time.
Old Feb 26, 2009 | 04:44 PM
degeze's Avatar
degeze
I have 18s but my wheels are 9.5" wide with a 45mm offset. Also, I am running 255/45 tires all around, with a 1.7" drop in the front. I don't have any problems what so ever.
I believe the widest tire you can use on the front is 10" without any issues.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
67LimeCoupe
Nov 25, 2015 08:55 PM
Tyoung68
Aug 25, 2015 04:31 AM
chain1
Aug 19, 2015 09:04 AM
