Cutting the stock antenna question
Old Mar 6, 2009 | 02:16 PM
Nuke's Avatar
Nuke
Default Cutting the stock antenna question
For those that have made their own shorty, how did you take the ball off w/o damaging it and were you able to simply re-glue it back on after cutting the shaft? I assume the shaft penetrates the ball somewhat.
Old Mar 6, 2009 | 02:50 PM
rfurley's Avatar
rfurley
I used a pair of pliers like a slide hammer and popped it off. Just pay attention to where the ball goes when it comes flying off of the antenna. I cut off the desired amount and super glued the ball back on. The antenna does penetrate the ball so it is pretty simple.
Old Mar 6, 2009 | 02:57 PM
Doogie65's Avatar
Doogie65
Here's the "how-to" I followed when shortening mine and it worked great...
http://www.mustangworld.com/ourpics/fcar/antenna1.htm
Old Mar 6, 2009 | 03:02 PM
Nuke's Avatar
Nuke
Excellent. Thanks, guys.
Old Mar 6, 2009 | 06:00 PM
degeze's Avatar
degeze
What he said.
Old Mar 6, 2009 | 09:28 PM
Shadow7874's Avatar
Shadow7874
you might not be able to just stick it back on though, the top is circular where the ball attaches but the reast of the antenna has a wire like thing wrapped around it. I had to gring the wrapped part down to fit the ball in. Wasnt much work just need a dremel with a cutoff wheel and a sander to smooth out the part to reattach at.
Old Mar 7, 2009 | 06:00 AM
Ato's Avatar
Ato
Reader Tip: For frequencies in the normal FM band (90-100Mhz) a length between 26 and 31 " will be fine. If you want to go smaller I recommend you use multiple of this ie 13 to 15.5" in order to maintain reasonable reception. - John the Ham radio operator and SVT driver (not at the same time :-)
This is an interesting note someone posted in that how-to. Right now I think I have an 8" from ebay and while I like the look the reception isn't that hot outside the city. Maybe I'll cut my stock one a bit and see if it improves the reception over the one I have now, that is if I can find it.
Old Mar 7, 2009 | 11:10 AM
PennState's Avatar
PennState
wish i just did this and saved myself 20 bucks
Old Mar 7, 2009 | 11:18 AM
Shadow7874's Avatar
Shadow7874
Im not sure what mine measure now but it sits level with the top of the car. Looks perfect to me, i hate the tall look, but the super short looks just as bad to me. I havent noticed much if any of a reception change and it looks great. plus free is always a plus
Old Mar 7, 2009 | 11:39 AM
Doogie65's Avatar
Doogie65
Cut mine to roof height as well and I do live in a rural area, with no noticable reception issues. Cheapest and easiest mod to date
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
jdphillips73
Aug 16, 2015 04:34 PM
