06 Driver side fender
1. Remove the front bumper cover.
2. Remove the fender splash shield.
3. Remove the 4 front rocker panel pin-type retainers and position the rocker panel aside.
4. Remove the 2 lower fender bolts.
To install, tighten to 11 Nm (8 lb-ft).
5. Remove the fender bolt.
6. Remove the fender support nut through the door opening.
Part Number Description
1 39001B Rocker panel pin-type retainers (4 required)
2 6310177 Rocker panel
3 W505421 Fender bolts (lower) (2 required)
4 W505421 Fender bolt
5 W505421 Fender support nut
6 W505421 Fender bolts (top) (4 required)
7 16006 Fender
7 16006 Fender
trashxtrash
09-20-2015 10:49 PM
