Tinting the break lights with store tint film.
I tried three different sections. I couldn't get a good bond between the light and tint itself. After I got a piece on I let it sit in the sun light for a while (hit 90 degrees yesterday) and when I went out later the corners were already coming up...I got frustrated and removed the lights to preps for the VHT Niteshade. I sanded them with 2000 grit and then sprayed a thin first coat. Let that sit for about 20-30 minutes and then sprayed a second (where I should have stopped) but I didn't get sprayed a 3rd and now the lights are a little dark for my taste. Believe I'm going to try and wet sand them today after work and see if it will lighten them up some, otherwise might bring out the paint thinner and rag and scrub away or either try to sell them to someone in the local mustang club around town.
How do you remove the rear marking lights on the sides of the rear bumper? I got to spray those and the front parking lights today also, and want to know how to get them out before I'm underneath the car. If I didn't get on mustangforums last night I wouldn't have been able to get the 3rd brake light out!
I haven't tried the VHT yet so I cant help you on the removal. I'd check the How To section on the forum.
As for your bond problem with the tint film before you did the VHT... did you put dishwasher soap on the tint (spray it) to make it stick better or did you just put the tint on without anything else?
Oh and how did the FIT itself work out before the bond problem?
Did cut a size that was close to the sections then finish it with a exacto while it was ON the car or what?
Did you put the tint just on the part of the three sections where the sections were sticking out and then curve it around the corner of each section or did you go over the actual outline that is NOT part of the actual light section sticking out?
Quick Pic from Cell...
Like I said they are a little too dark for my taste but going to work on that tonight by doing some wet sanding, and maybe starting from scratch if I can't get the look I'm going for with paint thinner!
