How To: Install GT, GT/CS, or GT500 Rear Bumpers
i got it painted for $100 by a neighbor
thanks for all the comments.
i just read it quick lol
$100??? LUCKY!
i paid $250 to get mine painted
Hell J, we could have taken those pictures ourselves when we did yours...
You were standing there.
And where did you stick this at?
Boozshey, unless you run 110 in your car, you don't need to disconnect the battery for unplugging electrical connectors.
Some people have a habit to undo said battery for anything they'll do to their car.
Makes them feel better.
You sure don't need to for replacing a bumper...
OP, I never separate the harness from its plastic support...
I disconnect the plug inside the trunk and feed it through the tail panel with the grommet
Everything comes off in one shot, including the harness.
I then separate the bracket from the bumper by drilling the rivets etc...but with the harness still attached to the bracket.
In no case at all, do I separate the harness from its support unless either one is messed up due to a wreck.
Makes things a lot easier...
Also, the factory paints over the texture on the CS bumper (on the front bumper as well)...
No need to sand it smooth unless you're after that look.
But I was tired when I was reading this....
Ill note disconnecting the battery as optional, i didnt, but most people do.
when i bought the kit it came with the support and everything already, so i just used the new one. Also i used it because i think the old one was a little messed up when i bumped into a jeep, so the new one was probably a little bit more strait.
im running 285/45-18 rear and they are a perfect fit inside the fenders.
