LED Third Brake Light
Old Dec 1, 2009 | 02:27 PM
fordracefan's Avatar
fordracefan
Default LED Third Brake Light
Does anyone have an LED Third Brake Light for an '08 Mustang?
American Muscle has one but it is only available for '05-'07.
Ninosports offers one for an '05-'09, but then states that Ford made a change that causes the LEDs to stay on even when the foot pedal is released on '08-'09.
I was hoping to get a smoked 3rd brake light to match the rest of my lights. I know I could tint the light and it is cheaper, but I would prefer to change out the assembly, and have the brighter LED lights.
Old Dec 1, 2009 | 04:20 PM
Nuke's Avatar
Nuke
Have you contacted AM to see if they have a kit for your '08? I'd think they'd have solved that problem by including a resistor to load the circuit so the LED's can fake out the SJB.
If it's simply a brighter light you need for the 3rd brake light, look into the Sylvania Silverstar 921ST lamp. It's supposedly 30% brighter than the standard 921 bulb. I put one in my g/f's '06 since she has the "MUSTANG" overlay on her 3rd brake light lens and needed more light. It did the trick.
Old Dec 1, 2009 | 06:39 PM
6+6 Stang's Avatar
6+6 Stang
in case you buy and have trouble see this issue a guy had, hope helps.
LED 3rd Brake Light Problem
Hello all. I recently purchased a LED 3rd Brake Light for my 07 GT. When I installed it, it worked great when you depress the brake pedal (as it should) However, when not depressing the brake pedal, the LEDs remain dimly lit at all times. I called the vendor that I purchased it from and they told me it was defective and sent me a new one. As soon as it arrived I installed it and I have the same issue. It works, but like I said, the LED's remain dimly lit at all times.
solution below:
I actually spoke to someone today that had the same issue. The fix was to install an in-line resistor. Apparently the LED's draw such a low amount of power (unlike a standard bulb) that they stay dimly lit from the constant "hot" source (unlike a standard bulb). So, the resistor actually prevents the LED's from drawing power (constant dimly lit) until the voltage is increased when you depress the brake pedal. It was a 4.99 item
Old Dec 2, 2009 | 01:59 AM
Mr.Bape's Avatar
Mr.Bape
That explains why my LED tailights burned out.
Old Dec 2, 2009 | 08:00 AM
fordracefan
Does anyone know what type of resistor needs to be put inline?
Old Dec 2, 2009 | 11:14 AM
157dB's Avatar
157dB
Cut & Paste Expert
The LEDS dont draw enough current.
A 7 ohm 20 watt resistor will fix that.
[b] Paralell the resistor inline, not in series.
Pep Boys or Auto Zone.
They only have one type there.
The correct type.
Old Dec 3, 2009 | 06:53 PM
neo1985's Avatar
neo1985
im sure it could be fixed with some easy mod
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
