antenna delete?
Old Jan 26, 2010 | 12:34 AM
ploe's Avatar
ploe
Default antenna delete?
so the roads were dry and the weather was fairly warm for a change, so i took my stang out of the garage for a spin..winter is too long; i couldn't hold out.
long story short, i take it to delta sonic (usually don't, just too cold to wash it :/) and they break my damn antenna off!!! i've been leaning toward taking the car to a body shop and telling them to delete the whole thing as if there wasn't supposed to be an antenna there at all.
has anyone successfully done this? i think i might have to have my dealer do it since they'd do a better job at matching vista blue...
do you think an antenna under the dash would give me good enough reception?
Old Jan 26, 2010 | 12:48 AM
Murphdog's Avatar
Murphdog
I'm not sure about under the dash, but I know there is a walkthrough about putting the antenna across the top edge of the front window that seems to work just fine.
Old Jan 26, 2010 | 03:35 AM
So_Cali's Avatar
So_Cali
Heres the Walkthrough
Old Jan 26, 2010 | 11:45 AM
shooter23's Avatar
shooter23
I did this on my last mustang - will post pics below.
The reception was um, well, none.
I also read about the antenna that goes in the window, and "apparently" it gets better reception...but never as good as factory.
The body shop I did it at, replaced the entire panel, i didnt want it filled, which is what most shops would do.
Kinda hard to see, but there used to be an antenna there.
Old Jan 26, 2010 | 06:07 PM
ploe's Avatar
ploe
thanks. how much did that set you back if you don't mind me asking?
so in the dash is a bad idea. reading the writeup it seems like accross the front window works. do you guys think running an antenna under the cowl or somewhere under the hood would work? it's just a little less work than ripping my interior apart lol.
Old Jan 26, 2010 | 06:16 PM
Cusp's Avatar
Cusp
They are cheep and easy to take off. I am taking mine off all the time. When I put the cover on and for the car wash. Takes 10 seconds. Put it in the trunk. Not really a problem. Its just on finger tight. Never has come off on its own.
My Ranger has the exact same antenna wire only silver instead of black. Same procedure for the ranger. Just unscrew it.
Old Jan 26, 2010 | 07:55 PM
chronos's Avatar
chronos
I think I read somewhere about someone installing the antenna in the A pillar. I don't know how well that would work. What you could do is put a power antenna in the slot and you wont have to see it unless you raise it. If you never listen to the radio and don't care then I say screw it and just get rid of the freaking thing all together. I unfortunately do listen to news and talk radio every so often so I wouldn't want a complete delete.
kevsgt
Oct 9, 2015 10:12 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
