CUSTOM BATTERY HOLDDOWN
Old Feb 28, 2010 | 01:53 PM
mustang queen's Avatar
mustang queen
Default CUSTOM BATTERY HOLDDOWN
Made the plate out of 1/4" aluminum . Cut the grooves with my radial arm saw with a carbide blade. Piece was too short so welded the end pieces on the ends. Painted grooves black and ploished the plate with a buffing wheel and rouge.
Hold down bolts are 10/24 covered that with chrome 3/8" faucet connection tubing , capped the allthread with acorn nuts powdercoated black. Will be getting a black GT to put in the center of the plate. Ford swap meet coming up in Columbus Ohio in April.CUSTOM BATTERY HOLDDOWN-battery-hold-down.jpg
Old Feb 28, 2010 | 02:20 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Good work! what is the total cost to make?
Old Feb 28, 2010 | 02:44 PM
mustang queen
2.00 aluminum, 2.00 allthread, 1.00 acorn nuts, 2.30 plumbing tubing= $7.00
Old Feb 28, 2010 | 09:52 PM
Ford-a-tude's Avatar
Ford-a-tude
Bridging the terminals of your battery with a chunk of aluminum...
PRICELESS!
Are you sure that thing can't shift a little bit and short out? That would be tragic if it did. Not trying to be a jerk, just looks kinda close to the terminals. Maybe split some fuel line and run it along the back edge as an insulator just in case.
Old Mar 1, 2010 | 09:29 PM
mustang queen
If the car gets smashed bad enough to move that plate . Then burn baby burn. PS there is a plastic strip on the back edge of the plate
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
mdg
Oct 1, 2015 07:04 AM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
