Interior LEDs
I got tired of the factory green so, with the help of another stanger I went ahead and did a swap to all white...here are the pics:
Also did the mycolor swap along with a leather wrapper steering wheel from on '07 Premium GT...
Looks good. Did you replace all the LED's in the radio/switches? I wanted to do this but it looks like such a pain. Is that a new gauge cluster? If so did you have the dealership flash the odometer to match your miles?
All in all... nice job!
It's in the view of the pic taken, so yes.
Perhaps you meant the doors and such? Curious myself.
Nice job OP.
I just got done ordering a few to check out to replace my non-mycolor cluster as I had it apart recently anyhow, and it finally bugged me to the point that I think I'll do it finally.
Also, what MCD(intensity)rating did you use? White ain't my thing, but I'm torn between red and blue, probably be the same as most and do blue, save the one button that I'm using for the PSU status.
Dreading the doors more than anything. Friggin' cold here.
Nice job OP.
I did the radio/ac/switches above radio...I still have to do the headlight switch and doors. The white was a little bright, I actually touched the top of each light with a sharpie to die it down a little. The mycolor cluster swap is a breeze, and I didn't worry about mapping the miles due to I know I will be keeping this car forever.
Looks awesome. I've looked at write-ups on swapping all the LEDs and decided I don't have the *****/patience to attempt it. But those are 3 mods I'd LOVE to do eventually
He just got back to be and said they are between 20-50 mcd
The white LED's where a higher MCD rating...that's why we had to use the black sharpie. It's difficult to find the white's in lower MCD's....bigger brighter stronger is the trend in LED's.
The reds I have are low MCD. They are a near perfect match to the intensity of the factory greens. I have done a few cars over on S197 forums. I've done white, blue, red and yellow. They all turned out pretty good.
Search my user name there and you should come up with some pictures.
RH
RH
jwog666
Dec 27, 2021 08:09 PM
treesloth
Sep 28, 2015 07:03 AM
