Redfire Paint question
Old Feb 17, 2011 | 11:39 PM
67stangr's Avatar
67stangr
Default Redfire Paint question
THhe paint code G2 is redfire and im painting 1/4 window louvers and was wondering if the primer has to be a gray or silver? Help!
Old Feb 18, 2011 | 03:18 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Doesn't matter...
Redfire covers pretty good as long as it's professional product, not from a rattle can.
Old Feb 18, 2011 | 08:22 AM
67stangr's Avatar
67stangr
Would the silver bring out the matalic flake better than gray or dont matter there either?
Old Feb 19, 2011 | 09:44 AM
pascal's Avatar
pascal
I won't make much of a difference.
Old Feb 21, 2011 | 07:30 PM
2007redfire's Avatar
2007redfire
I believe the base coat from the factory on redfire mustangs is silver. if you have any chips in your paint youll be able to see down to the base coat and check. either way, gray or silver, i dont believe itll make a difference.
Old Feb 21, 2011 | 08:36 PM
pascal's Avatar
pascal
You believe wrong I'm afraid.
The factory uses a grayish etch primer on the bare metal, then it's straight to the base color that is selected for a particular car and the clear finishes the whole deal.
It would be too costly for Ford to use a sealant before applying the color, and the advantage would be minimal.
tmdm
May 2, 2021 02:49 PM
guitarman376
Oct 11, 2015 01:47 AM
Ipaman
Sep 22, 2015 07:01 AM
mustangchef
Sep 4, 2015 08:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
