Belt Issues
Old Jan 15, 2012 | 11:00 AM
fast03stang's Avatar
fast03stang
Default Belt Issues
Hello i have a 05 Saleen, i have installed 3 different belts on the car, all three broke with in 15 secs of running. I have checked all the pulleys, they spin freely and are not bent, there are no sharp spots on the pulley that can cause the belt to break. The only thing i noticed is the Crank pulley sits about 3/8" of an inche farther out then the rest of the pulleys. Could this cause the belt to break and if so how do i fix it, do i need a new crank pulley?
Old Jan 15, 2012 | 07:47 PM
JimC's Avatar
Super Moderator
Pulley mis-alignment will break belts. While the pulley may stick out further though, is that due to size (it is a little wider)? or is it a case of not being in line with the others? Does the belt rub at that pulley, or does it ride on the inside?
Old Jan 16, 2012 | 09:55 PM
amustangrocks's Avatar
amustangrocks
heck ya thats a problem. need to figure out why that pulley is out of wack. maybe the pulley might be failing and coming apart? ( happened on my 4.0, and is pretty common) or its not on all the way. 3/8" is huge.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
