Whats Better: Slotted or Drilled............
They do the same thing. It provides a void for gasses to go durring hard braking. Drilled will be a little cooler as the holes basicly make them a heat sink, but they will only ever get hot enough to notice if you are auto-X racing. For a street car both are mainly for looks, so get what you think is the best look for you.
Thanks for the info.
ORIGINAL: The Ghost
ORIGINAL: The Ghost
yeah i don't auto-x race or anything I just want something that will look better than the stockers and if they help performance wise at all even better.
With drilled rotors on a street car your going to look forword to replaceing them frequently. They have a huge tendance to crack when they are heat cycled repetatively, especially if they get wet.
With slotted rotors look forword to buying pads more frequently, the slots actually shear off a microscopic amount of pad material on every rotation with the brakes engaged (Thats how they sheer away the gasses).
Neither are really great for street driven cars, blanks are the way to go for a daily driver.
SLotted reales excess gas which helps for a better braking surface where drilled releases heat. For a long time ppl said to not run drilled for everyday use, that they cracked, but things have gotten better. If your goin for looks, id definitelyt do drilled and slotted. Im ordering a pair of ROTORA here ina week or so
When did that change? I know of a lot of people that still have problems with cross-drilled cracking, zinc plating doesnt help, nothing helps its just the nature of steel to crack under the stress. If things have changed though then I am definatly getting a set because they look great and certainly help with fade.
Cool, I can finally share here from a career point of view. I work in one of the most productive steel mills in the world. You would be blown away by what we can make steel do under certain conditions. For instance, in bridges and tall buildings we have steel that actually gets harder the more stress that is induced. For cars and such we have steel that will get harder as it is crumpled in order to create a buffer effect and limit the amount of compression, you may have heard it called energy absorbing. We can make "quiet steel" or low conductive steel. Metalurgy has progressed to mind blowing proportions. So...can brake rotors be made that do not crack, absolutley. The Q is does the average company offer such a rotor. Really, I would imagine that most machine shops go with the most cost effective steel. But, even common carbon grade steel is 100% better than it was 10 years ago. And because I am a machinist by trade, a simple chamfering of the cross drilling will prevent cracks. Heat cracks "stress" propogate from sharp edges, a standard countersink will normally cure this problem. Will the E-bay rotors offer this, maybe not. Ask Q's to the manufacture if this concerns you. I still stand by for a street ride rotors are strictly for looks. There is a very slim chance that you will heat them up enough to ever notice a difference at all.
