Sct2 Help
Old Mar 1, 2006 | 06:43 PM
cfr865's Avatar
cfr865
Default Sct2 Help
I recieved my Sct2 tuner from Doug at Bamachips, I plugged it into the computor port and nothing happens the Sct doesn't even light up, Did I get a bad one or I'm I doing something wrong.
Old Mar 1, 2006 | 06:47 PM
PonyPilot's Avatar
PonyPilot
Default RE: Sct2 Help
My recollection was that when I used mine, I had my key in the ignition and power accessory to on...If you've done that, then I don't know what to tell you...other than call the vendor.
Old Mar 1, 2006 | 09:07 PM
BlackB-U-TEE_06's Avatar
BlackB-U-TEE_06
Actually, the SCT2 should turn on immediately upon plugging it in. you don't even need your key in the ignition at first (although you'll need to put it in eventually). send it back.
Old Mar 1, 2006 | 09:25 PM
cfr865's Avatar
cfr865
I going to send it back, waited 10 days to get then it don't work. Not real happy, where's the quility control ?
Old Mar 1, 2006 | 09:35 PM
one_focused_svt's Avatar
one_focused_svt
ORIGINAL: BlackB-U-TEE_06
+1 just plug her in and get started! oh and thats why you should have used brenspeed
Old Mar 1, 2006 | 09:56 PM
Stoenr's Avatar
Stoenr
Make sure no prongs got bent. Possibly try in another 96 or newer ford to see if it powers up. If not cal him up, see if he can send you a replacement out and a return tag for the old one. And request a Cross ship so you dont need to wait any longer.
Not using brenspeed isnt the issue! Not even fair to say that. Ive heard nothing but good stuff about Bamachips. Although I did go
with Brenspeed and shipping is FAST. Customer service great too.
Old Mar 1, 2006 | 10:22 PM
one_focused_svt
ORIGINAL: Stoenr
DO NOT TRY IN ANOTHER VEHICLE!!!!! From what I understand as soon as you plug in your tuner it burns the VIN into the tuner making it so you can only use it for that specific VIN. So lets say be freak accident it works in another car, then you can't use it in your own, and the manufact. will tell you your SOL!
Old Mar 1, 2006 | 10:23 PM
Stoenr's Avatar
Stoenr
Lol, where tha helll did you hear that at? FALSE
Old Mar 2, 2006 | 01:54 AM
Badash's Avatar
Badash
ORIGINAL: one_focused_svt
The tunes I got from brenspeed are less that desirable. Actually my stock tune is better.
Old Mar 2, 2006 | 02:21 AM
danalor's Avatar
danalor
I find that hard to believe, but believe it I must since it's your car and you would know better than anyone else. Me I'm quite happy with the tune Brent did for me.
