2006 NHRA Rules
Old Mar 3, 2006 | 01:51 AM
F00Mustang's Avatar
F00Mustang
Default 2006 NHRA Rules
I'm eager to run in the Fun Ford Weekend comming up in may in Louisiana in the new Ultra Stang class, but I have a convertible. By the time this comes, this car will be well into the 12's. No Problem Raceway follows the same rules as the NHRA rulebook regarding safety and inspections. Does anyone have an NHRA rule book who could tell me if I will run into any problems with tech. I want to know soon so that if any modifications need to be made, I can make them.
[IMG]local://upfiles/20840/9E4F963C47864D4E954C17B8022A8F31.jpg[/IMG]
Old Mar 3, 2006 | 02:34 PM
chevykiller's Avatar
chevykiller
I ♥ Acer
Default RE: 2006 NHRA Rules
You need a roll bar if you are running faster than 13.49 ET with a vert. Note - I said roll bar not a full cage. Here is a quick rule referrence guide that should help you out...
http://www.nhra.com/tech_specs/ETQuickRef.html
Old Mar 3, 2006 | 03:35 PM
Birdieman4's Avatar
Birdieman4
They changed the driveshaft loop rule as well this year, I believe as well.
Old Mar 3, 2006 | 03:45 PM
chevykiller
I ♥ Acer
ORIGINAL: Birdieman4
Birdie's right - thanks for pointing that out. What's not on the cheat sheet I gave you is the drive shaft change they made this year. You're going to need to put a safety loop on your driveshaft if you're in the 12's. They aren't very expensive and they are an easy bolt on deal. Definitely follow the rules cause in my experience, tech seems to be a little more thorough with verts...
Granatelli Sales
Jan 20, 2020 12:34 AM
PullTab
Oct 30, 2015 08:46 AM
kevsgt
Oct 9, 2015 10:12 PM
BeatnikFink
Oct 1, 2015 08:00 PM
BrantleyS550
Sep 14, 2015 04:18 PM
