Rice or not?
Old Mar 5, 2006 | 12:17 AM
  #21
Black06stang's Avatar
Black06stang
Default RE: Rice or not?
yeah....I am not sure if I am interested in these rims anymore. I emailed the guy asking what his reserve is, and he said it was higher than $1500!!!!!!!!
Old Mar 5, 2006 | 07:18 AM
  #22
skilz4u2nv's Avatar
skilz4u2nv
Yea they are not cheap especially if you wrap them in good tires... i am going to get them brand new from tire rack with high performance tires for just over $2000 shipped...
Old Mar 5, 2006 | 08:25 AM
  #23
Herknav's Avatar
Herknav
ORIGINAL: Black06stang
So....will the extra weight affect the way my stang drives? I love the way the mustang handles as it is. I know the ride quality will be a little bit worse because of the 20 inch rims...but its nothing serious, right?
Yes. You are asking your car to rotate additional weight on each wheel. Your acceleration will suffer.
Old Mar 5, 2006 | 09:57 AM
  #24
grasshopper's Avatar
grasshopper
There might be a slight "clunkyness" over quick bumps, cracks, seams, joints, etc. The mass is slowing the ability of the suspension to react. Definitely slower acceleration as well.
The worst handling issue will be when you have to handle tire rotation, unless you have someone do it for you.
Old Mar 5, 2006 | 12:03 PM
  #25
Black06stang
How noticeable will the slower acceleration be? After years and years of having these tires and wheels on....will it hurt my suspension quality. BTW the overall tire diameter is the same as stock. What is the stock rim width? Also will the ride quality be that poor?
Old Mar 5, 2006 | 12:55 PM
  #26
Black06stang
I cannot find the place that said the 20 inch Zinik Z9's weigh 35 lbs each. Does anyone know where I can find how much they weight? I have searched everywhere and cannot find the weight of the wheels anywhere....
Old Mar 5, 2006 | 01:58 PM
  #27
skilz4u2nv's Avatar
skilz4u2nv
I dunno where that website is either i tried looking for you but I do rmemeber they were 35lbs or was it a +35 offset... hmm now im confused... no wait it was 35lbs i think...
Old Mar 5, 2006 | 02:24 PM
  #28
Black06stang
Thanks for lookin skilz4u2nv...I'm just trying to do some research before I purchase.
Old Mar 5, 2006 | 02:59 PM
  #29
jbailer's Avatar
jbailer
I think the wheels look great and as others said, buy them for yourself, not others. If you like them, that is what is important. I'm buying black 20" as well, the Raceline GTs. Regarding the weight and suspension/handling, the weight of things that the engine is turning is refered to as "un-sprung" weight and is a big area for performance improvement. Things like the weight of the drive shaft, wheels and pulleys. It's not going to hurt your car to run with heavier wheels and it's not going to make your car crawl. If you race your car, you will notice a little difference. The suspension is fine too, it isn't going to hurt the suspension.
By the way, did you notice the sizes? Looking at 1 site's application guide showed that the only width they have with the correct back-spacing is 8.5". Are you ok with running 8.5" wheels on the back? It's probably ok if you stick with maybe 255/35/20s but if you wanted to go any wider on the back, you might want to consider a wider wheel. I've read where people have gone as wide as 10.5" on the back with 10" being very common. The Raceline GTs are available with a staggered width of 10" for the rear and 8.5" for the front as a set. Also it is good to pay attention to the back-spacing. The back-spacing for the 2006 is different from the 2005. If you buy wheels for the 2005, I'm told you will need a 1/4" spacer for the 2006. -Joe
Old Mar 5, 2006 | 04:25 PM
  #30
Black06stang
jbailer brought many issues to my attention. First of all, can anyone else confirm that the backspacing is different for the 2006's than the 2005's? What is the stock rim size for the rear? Will this look odd if I have 255/35/20's in the rear? I really like the staggered look...
