Last edit by: IB Advertising
Browse all: Lighting
- Ford Mustang V6 and Mustang GT 1994-2004: How to Replace Your HeadLights and Fog Lights
Step by step instructions for do-it-yourself repairs.
anybody change headlight/foglight bulbs?
RE: anybody change headlight/foglight bulbs?
I got the "high wattage" low beams and the H10 fog lights from NOKYA also. Come on guys, admit it, the low beams SUCK. Yes they give a blue color, but the light output is way less than the stock bulbs. If you install one and look at them from the front of the vehicle or from inside the car the difference is obvious. I took them out after 2 days. I hav'nt driven my car at night, or at all since november in fact, but anyone using there car at night alot, especially in the winter would not want these. You really can't see very far down the road.
I fog lights, however I'm satisfied with. They are blue in color, seem to project just as much light as stock and look cool from the front of the car. I havn't had any issues with the melting that was mentioned by others. Just don't want anyone else to throw away good money like i did. I hear that Sylvania WON'T be producing an H13 silverstar, so if anyone has used a different brand with different results I'd like to hear it.
[IMG]local://upfiles/16153/8FCDD0911B27430CA88009E1EE2EC275.jpg[/IMG]
I know, holy thread revival. However, I did want people to know I at least did a search before asking what may be a stupid question. Is there a right-up on how to change the headlight bulb in the 05+ Mustang? I've been able to find plenty of debate on which H13 bulb to buy, but no info on how to actually change the bulb. Is it something simple like disconecting the the bulb from the rear of the headlamp housing or is there more to it? Thanks.
I replaced the stock hedlight and fog bulbs with Sylvania Silverstars, the do provide a whiter light and IMO are the best choice when it comes to bulbs.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
High wattage bulbs might be illegal in some areas and I've heard many times problems like the ones mentiones in this thread .
The next step for me will be xenon personally I'll do it for function more than appearence and I preffer whiter light in the 4300 - 5000 color temp range also the consume a fraction of the power required by conventional bulbs.
ORIGINAL: Plaidpony
Do not touch the glass bulb part of the bulb when replacing.....
For the fogs, you need to remove the top cover over the radiator, remove the two bolts from the top of the grill assembly, and pull the top of the grill back to get to the fogs. Then twist and replace as noted above. I went with Silverstars in both, and love them....
Mike
ORIGINAL: Plaidpony
ORIGINAL: mlcrycc
For the headlights, it's as simple as twisting the bulb from the rear of the headlight, and replacing with the new one. Take care, however, to make sure you remove the rubber gasket from the old bulb, and use the new gasket that comes with the bulb. Sometimes the old gasket will stick to the housing, and then you are trying to re-install with two gaskets....won't work....
Mike
ORIGINAL: Plaidpony
Mike
You have to be careful on the fogs because you can knock out the little metal clip inside the housing and it is a PITA to get back in place. Some guys have gone so far as to replace the fog because they couldn't fix it. It's like playing the game "operation" when you were a kid, you can't touch the sides...lol.
Didn't see them mentioned, I'm running Silverstars, got them at the Zone, $80 for all 4 bulbs:
Noticable but not significant improvement.
More useable light than stock. Whiter light to, looks better. Not HID or HID look alikes by any means though.
