Which L/T Headers??
Old Mar 27, 2006 | 06:34 PM
FIREMNSGT's Avatar
FIREMNSGT
Default Which L/T Headers??
I've been wanting to get some long tube headers, best price so far is RPM Outlet (Hooker ceramic $599, JBA Stainless $599) I've read some people having good experiences with the Hookers, any imput would be great..do I need motor mounts? will I lose low end power? Thx in advance..
Old Mar 27, 2006 | 07:10 PM
F00Mustang's Avatar
F00Mustang
Default RE: Which L/T Headers??
I wanted to use the JBA's but ended up going with the hooker's just because of the price. I love them. They'll take a day to install, so leave yourself some time. It is definatelly worth it to get the motor mounts at the same time. The mounts I bought came from Granatelli and only cost me $120. Three bolts on eact mount, and there done (very easy with the manifolds allready out).
As far as power, I gaines power across the entire RPM bank, including the low end.
Old Mar 27, 2006 | 07:17 PM
burnout42's Avatar
burnout42
You may want to do some more research before you spend that money. I have read 2 articles already with dyno tests that show a whopping 5 pony increase to the rear wheels after long tube headers. That is pretty krappy horsepower / dollar ratio. Apparently, the stock manifolds are a very efficient design already. I would spend the money elsewhere. Both articles I read were on forced induction '05 stangs, so even pushing a ton more air into the motor doesn't help much with the LT's. If that is the case, save your money and do something else. Unless you are just trying to get a different exhaust note.......................pretty expensive though.
Old Mar 27, 2006 | 07:34 PM
F00Mustang's Avatar
F00Mustang
The articles that burnout is referring to are comparing the shorties to long tubes, which that is correct, you will only see a difference of about 5hp between the 2. But I picked up about 20 horses at the wheels by changing out the stock manifolds, so It does help, but a retune is needed to deliver the power potential. This is especially true when your talking about forced induction, as the intake side of the system is not as important as getting the spent gasses out.
As for "why longtubes?". I did the long tubes over shorties because of the exhaust note. I have perfect strangers tell me my car sounds great, and I attribute the better sound to the long tubes and cat delete.
Old Mar 27, 2006 | 07:48 PM
andyman's Avatar
andyman
Make sure that whatever you get is CERAMIC COATED this way it won't discolor or rust. the hookers are real nice, that is what I have.
https://mustangforums.com/m_1170524/tm.htm
Old Mar 27, 2006 | 08:25 PM
FIREMNSGT's Avatar
FIREMNSGT
Thanks for all the info..[&:]
Old Mar 27, 2006 | 08:49 PM
Tik_Tok's Avatar
Tik_Tok
I've got SLP long tubes.... they should be here within the next 2 hours.... YAY! I'll tell you how the quality looks when I get them, and how they sound tomorrow night.
Old Mar 27, 2006 | 09:10 PM
Tik_Tok's Avatar
Tik_Tok
[sm=massbounce.gif]
Literally as I hit enter on my last post, the UPS guy knocked on my door.
Long Tubes are here, they look good, all the welds are pretty decent. NOT impressed with the X-Pipe though, welds aren't nearly as good looking as the headers, and one outlet port is slightly bent (that might have been from the shipping, though the boxes don't look knocked up at all)
Old Mar 27, 2006 | 09:18 PM
FIREMNSGT's Avatar
FIREMNSGT
Tik-Tok can I ask where did you get your set-up from?? let us know how the install goes...
Old Mar 27, 2006 | 09:31 PM
Tik_Tok's Avatar
Tik_Tok
ORIGINAL: FIREMNSGT
LMPerformance, they took a few days to ship it, then UPS took FOREVER to get here (mind you I am in Western Canada) I will try to post before/after vids or sound for everyone.
