How do you get the radiator cover off?
RE: How do you get the radiator cover off?
Like Scooter said...Use a flat tip to pop out the center piece of the plastic pin; but DO NOT pull up on it! Use the same screwdriver to pry up the bottom piece after you have popped up the center piece. If you just pull up on the center piece it will break off. Take out all the push pins and then lift the cover right up, it will be loose and come right off.
i hope all you are planning on doing is altering the grille or the like. If pressure clips are difficult to figure out, im a little concerned about you altering any portion of the engine parts. No offense intended....just saying.
-C
-C
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
