Attn: Lowered Mustangs
Old Mar 31, 2006 | 11:56 PM
grafix66's Avatar
grafix66
Default Attn: Lowered Mustangs
So, I installed my Eibach Pro Kit on my 2005 Mustang today and put on 20" rims and tires. I take a look from behind and notice that the tire on the driver's side rear sticks out past the rear wheel well about a half inch. Look at the other side and the tire is inside the wheel well a half inch! It seems the axle is skewed towards the drivers side somehow. I double checked the rear spacing on the wheels to make sure they were the same and everything measures up. So...what happened? Has anyone else noticed this after lowering your mustang and do you know a fix?
On another note, the tires are larger than stock and I have to set the Revs per mile on my SCT tuner. Are the RPMs based on the size of the rear tires or the front tires? Thanks!
Old Apr 1, 2006 | 12:00 AM
DUSTI's Avatar
DUSTI
Default RE: Attn: Lowered Mustangs
Graffix,
I had the VERY SAME thing done today (20's and Eibachs that is) but
didn't notice the problem you're having .
DID you get the wheel alignment done AFTER the spring installation ?
What kinda tires you got in the rear ? I got 275/35/20 and it seems to
be o.k.
DUSTI
Old Apr 1, 2006 | 12:01 AM
hawgman's Avatar
hawgman
I ♥ Acer
You need an adjustable pan hard rod to recenter the rear axle. Every lowered S197 does this. You just happened to notice it more because of your tire/wheel combo. Get one from BMR your problem will be solved.
Old Apr 1, 2006 | 12:03 AM
blackout's Avatar
blackout
I have the same thing coming on Tuesday, the only difference is I have eighteens and mines coming with an Alignment Kit. Hope everything works out for the best with it. The Alignement Kit is only thirty dollars and hopefully is worth it.
Old Apr 1, 2006 | 01:56 AM
Tik_Tok's Avatar
Tik_Tok
Since someone answered your question, and while we're talking lowering...
Do any of you guys with lowered stangs have Headers??? I'm curious because after I installed mine, the headers are REALLY close to the ground, and I haven't lowered mine... any problems out there?
Old Apr 1, 2006 | 02:18 AM
DStang05's Avatar
DStang05
I have the pro-kit and damper kit on my 2005 Gt. I also have the JBA headers installed(cat4 shorty) even with the Steeda motor mounts I still get the headers hitting the fender well frame the my passengers side on a hard left turn.
Old Apr 1, 2006 | 02:19 AM
Badash's Avatar
Badash
I havnt lowered my mustang, yet when i put on my new rims and tires I had the same issue.
Old Apr 1, 2006 | 02:26 AM
blackout's Avatar
blackout
I hope I don't run into problems with my headers scraping, I just ordered my Eibach Pro Kit Springs along with my Hooker X-Pipe. My Hooker L/T Headers will be ordered sometime next month. Anyone have this setup with the Hooker L/T headers, they are supposed to have the same clearance as the stock headers.
Old Apr 3, 2006 | 11:26 AM
grafix66's Avatar
grafix66
Thanks for the reply. The panhard rod may be the way to go. I'll call Eibach and see what they have to say, as well. BTW, after installing the Eibachs on a mobile floor lift and setting it down, There wasn't enough clearance to back the car off!. I had to grab some planks and lower it onto them and then back the car off on the planks. Just a heads up to anyone out there. The car looks great, though.
Old Apr 3, 2006 | 01:18 PM
fairlane292's Avatar
fairlane292
Agree with Hawgman: I used BMR adj panhard and easily aligned to within an 1/8", one side vs. the other.
