My Mod List
Here's my complete mods list:
ENGINE:
302 stroker kit on 4.6 aluminum block bored to 5.2 liter
Forged pistons, rods, crank
Valvatrain by compcams with butterfly valves, rings, springs, cams, gaskets, etc.
Mezuire Water pump
CPR fuel rails
Dual fuel pumps
Kenne Bell Boost-a-pump
#60 injectors with adapters
H20 cold plugs
HD engine mounts
Cobra radiator conversion
Custom heat exchanger
Steeda Charge motion delete plates
Vortech icebox water overflow
Votech h/o s/c with aftercooler 3.61 pulley @ 14 psi
Predator with MAF.i.a.
NOS Nitrous set-up with 150 fogger jets (all the goodies - bottle heater, opener, purge kit, blowdown, blanket, etc...)
-8 Fuel lines in entire car
Batttery relocation to trunk
Windage tray and 9 qt. oil pan (coming soon)
ARP head studs
MSD electronic window switch
aluminum radiator cover
billet caps
custom plenum cover
Custom quick-connect water system
Custom mount electrical box and fuse box
JBA Long tube headers
Custom H-Pipe
Borla Exhaust
Roush tips
DRIVE TRAIN:
Aluminum Flywheel
4.10 gears
Eaton Posi
Clutchmaster stage 4 clutch
pro 5.0 shifter
SUSPENSION:
Eibach springs
Billet strut tower brace
adjustable front swaybar
Billet camber adjusters
Competition end links
Control arm relocation (front)
Competition upper spring seats
Metco upper & lower control arms (rear)
Race panhard bar
HD swaybar chasis link
swaybar end links
trunk brace
subframe connectors
torque box brace
EXTERIOR:
Roush body kit
Cervini 1/4 window vents
Cervini side vents
CDF hood
Custom painted stripes (coming - vinyl for now)
Custom badges/emblems from all over
clear signal lamps with stealth bulbs
toyo 245/55 tires on chrome billet 18x10 rims (street)
Hoosier 28x15 - 11.5 slick on 15x10 bogarts rear - MT ET Slick 26x15 - 4 on 15x4 bogarts up front (RACE)
Shark teeth license frame
68' gt500 tire caps
INTERIOR
Double pillar gauge pod with lunar series gauges
complete roush interior
blue c/f complete trim
custom mounted gauges above glove box
shift light w/adapter
shift boot, e-brake boot, and console cover from redline leather goods
Roush pedals
Roush white face dash
Billet *****/switches
custom switches
Everything else pretty much stock...lol
http://homepage.mac.com/chevykiller/
EDIT - With the exception of the couple (coming soon) stuff - all of this stuff is either on or being put on right now.
ENGINE:
Mezuire Water pump
CPR fuel rails
Dual fuel pumps
H20 cold plugs
HD engine mounts
ARP head studs
billet caps
custom plenum cover
Custom H-Pipe
Borla Exhaust
Roush tips
DRIVE TRAIN:
Aluminum Flywheel
4.10 gears
Eaton Posi
pro 5.0 shifter
SUSPENSION:
Eibach springs
Race panhard bar
swaybar end links
trunk brace
subframe connectors
torque box brace
EXTERIOR:
Roush body kit
Cervini side vents
CDF hood
68' gt500 tire caps
INTERIOR
Roush pedals
custom switches
Hey mark... I needed to scroll down 2 times to read the whole list... Congrats... I am sure your car is going to come out like a BEAST!!!! Can you PM the info on the ice cooler box, I tried to find it on the internet yesterday but i couldn't. How was the track yesterday... ???Did you smoke some Vettes...? Are you comming tomorrow to arcadia, we have like 9 cars comming so far....
ORIGINAL: silverpoison
I've got church at 11:30 tomorrow morning so I don't think I could make it back in time. Keep me posted on the next ones and I'll try to come out one time. But Knotts is next sunday (April 9th) so we will be seeing LOTS of guys there from all over...
ORIGINAL: spyder7724
mark,
you didn't say what kind of floor mats you have and if they were striped or not.lol
mark,
