mustangs weight ?
Old Apr 4, 2006 | 06:07 PM
saud alzaabi's Avatar
saud alzaabi
Default mustangs weight ?
well guys on my mustangs registration card it says the mustang is 2000 KG so i'm not sure is it true or not ? because i searched every where and couldn't find ... lol well NOT every where but lets say i did a fast search.
Old Apr 4, 2006 | 06:10 PM
Tik_Tok's Avatar
Tik_Tok
Default RE: mustangs weight ?
No way in HE77!!!
That's 4400 lbs! With a driver and full tank of gas, mine weighed in at 3550 lbs.
Old Apr 4, 2006 | 06:12 PM
gregt909's Avatar
gregt909
ORIGINAL: Tik_Tok
No way in HE77!!!
I was trying to remember the conversion table but I think you're right. 1 kilo = 2.2 lbs. Yeah that's not correct for your weight.
Old Apr 4, 2006 | 06:29 PM
6xStang's Avatar
6xStang
what does it say on your titles/registrations? I seem to remember reading somewhere that the GT Coupe weighed 3470 dry? That sounded heavy to me. 3550 with ~180 pounds of driver (sorry if I am way off) and 100 pounds of fuel sounds about right.....
I think the ragtop may be about +50 pounds.......
my 89 5.0 coupe was about 3050 pounds dry, as I recall.....and the ragtop is about +100.....
This is all based on printed specs or recollections thereof; I never had anything weighed except trailers.
D
Old Apr 4, 2006 | 07:56 PM
EJD05GT's Avatar
EJD05GT
2005 GT's Curb Weight lists at 3,450 lbs.
-E
ORIGINAL: saud alzaabi
Old Apr 4, 2006 | 08:02 PM
ChewbaccaD's Avatar
ChewbaccaD
I believe the 'vert weighs 125 lbs more.
You should be in the ~3500lbs range. If memory serves, the weight should also be listed on the inside of your driver's side door frame.
Old Apr 5, 2006 | 01:30 AM
Juntech's Avatar
Juntech
kinda off topic but how much do the power seats weigh? what kind of weight loss can one expect from getting racing seats? any weight reduction methods?
Old Apr 5, 2006 | 01:37 AM
spyder7724's Avatar
spyder7724
i've read the seats are about 50lbs each and the rear seat is over 40lbs. my car weighed in at 3300 w/o driver. i do have a few things done to lighten the car up which is worth about 200lbs. the auto trans is 50lbs heavier also. verts are 125-150lbs. heavier.
Old Apr 5, 2006 | 01:49 AM
grasshopper's Avatar
grasshopper
2000kg is the Gross Vehicle Weight Rating (GVWR), or the total of the car's weight plus it's maximum safe cargo capacity. It's on the sticker in the door jamb (actually 2019kg for my GT coupe). This is the weight that the government cares about 'cos it tells them how much potential damage you can do to their roadways.
Old Apr 5, 2006 | 09:14 AM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
ORIGINAL: grasshopper
+1 DMV's usually go by GVWR, they don't care what a vehicle weighs empty just the total weight capacity of the vehicle.
