Single Point Jacking
Old Apr 5, 2006 | 10:37 PM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Single Point Jacking
ORIGINAL: 351PONY
OK, Hawgman, where did you get the diagram? I want to blow this up and post it on my garage wall for future reference...hehehe
Came from the service DVD.
As for jacking it up by the diff., two reasons why not to. One is obviously saftey. The other is you can actually cause your diff to leak.
Old Apr 5, 2006 | 10:41 PM
jbailer's Avatar
jbailer
Oooops, I never even looked in the owner's manual. Does it happen to say the propper torque for the lug nuts? I'd look but don't have my car or owner's manual at the moment. -Joe
Old Apr 6, 2006 | 12:01 AM
trey929's Avatar
trey929
100 ft lbs rings a bell and thats what i got mine at.
Old Apr 6, 2006 | 12:04 AM
cyberjock4hire's Avatar
cyberjock4hire
Yes, 100 ft/lbs. That's what the manual states.
Old Apr 6, 2006 | 12:23 AM
cinque35's Avatar
cinque35
had an '88 that started leaking after i jacked it up by the diff. bent the cover out a little.
it also warps the axle, the load of the car goes down the springs to the axle shaft near the wheels, the diff housing should never bear the weight of the car.
you may get away with it once (or a hundred times) but why take the chance of messing up your own car.
those ppl at the tire places don't care about your car, they just do what's easiest for them.
(that diagram is an ’04, but should be the same points on the S197)
Old Apr 6, 2006 | 02:50 AM
Skrappy's Avatar
Skrappy
I have lifted mine up in a few different places besides that and had no poblems structurally. Though I never tried to do more than one corner at a time and took my sweet time setting her up... I would have liked to have this picture around, just would have given me a little more confidence...
Skrappy
Old Apr 6, 2006 | 03:35 AM
Mister Roper's Avatar
Mister Roper
FYI, Hawgman is 90% BS 100% of the time. Or is it the other way around?
j/k lifting from a single point at the diff can cause flexing in the metal. Even if the jack point is not touching the cover you risk the flex that will cause a leak.
Old Apr 6, 2006 | 11:53 AM
hawgman's Avatar
hawgman
I ♥ Acer
ORIGINAL: Mister Roper
You're too kind Stanley. That ratio is a little low And depending on the conversation and who it is that I have insulted or pissed off at the time, some folks say that I have NEVER had anything nice to say or contributed in any way.... Of course the funny part about that is, it is usually someone that a week prior was thanking me for something.
Old Apr 6, 2006 | 01:49 PM
torch red's Avatar
torch red
I always jack off on the shaft-----ooooops
Oh, u mean jacking up the car---my bad...[:-]
Old Apr 7, 2006 | 01:00 AM
RazorX's Avatar
RazorX
This is great information and very timely as I just ordered a set of springs that I plan to install myself.
At the risk of asking dumb question...
How do you jack the rear of the car up, using a floor jack, to put it on jack stands considering the only jack points in the rear are to the outside edges?
