lighting...
Old Apr 27, 2006 | 06:16 PM
linernotejunky's Avatar
linernotejunky
Default lighting...
going to switch out for some bright whites/blueish bulbs for both headlamps and fog lamps. so before i go-a-purchasing later today, any preferences by anybody?
Old Apr 27, 2006 | 06:39 PM
MJDGator's Avatar
MJDGator
Default RE: lighting...
Be careful, some of those lights run much hotter than stock and can damage/melt your headlight. Check out Sylvania Silver Stars to start with. They are white not blue. Most of these types of bulbs have a much shorter lifespan as well. If you want the HID look your best bet is to poney up the $$$ and get an HID kit or the Saleen lights.
Old Apr 27, 2006 | 07:13 PM
classj's Avatar
classj
Check our daniel Stern lighting. he has alot of great information about choosing bulbs for cars. I have the silverstars in another car, they arent so great. The blue tint on the glass of the bulb actually hinders performance. They arent brighter by much as any gains gotten by overdriving the bulb are mostly lost in the blue coating.
Old Apr 28, 2006 | 10:19 AM
BeeStang's Avatar
BeeStang
Take this advice seriously... It happened to me. I put yellow 25 watt bulbs (Xenon) in my fogs and the melted the lens and the metal bulb shrouds loose. The bulbs in the mustang are a special design (H13) that push the bulb out and away from the lens. Look closely and you'll see what I mean. It might be more obvious if you look at them when they are removed from the socket. You might consider HID for the main headlights, they are much cooler than quartz bulbs and Silverstars for the fogs.
Here is a HID setup with both high and low beams. Becareful if you choose another brand, as some only have just the low beam (no high beam). Also, this setup is less expensive than the Saleen setup (Saleen is about $850).
http://www.bulbman.com/index.php?mai...ducts_id=15989
ORIGINAL: MJDGator
Old Apr 28, 2006 | 11:13 AM
PullMeOverRed05's Avatar
PullMeOverRed05
I just ordered a Halogen Ultra Whites (H13 and H10) from http://automotivelightingusa.com
Anyone have any experience with these? They should be arriving today.
Old Apr 28, 2006 | 12:30 PM
linernotejunky
i thought it was H13 for the headlamps and 9145 for the fog lamps. is that not right?
Old Apr 28, 2006 | 12:37 PM
PullMeOverRed05
According to their website, its the H10s
http://www.automotivelightingusa.com...f226aed0239955
Old Apr 28, 2006 | 12:58 PM
linernotejunky
yeah, the 9145's are the sylvania #. cheers.
ORIGINAL: PullMeOverRed05
Old Apr 28, 2006 | 01:43 PM
razol's Avatar
razol
Just a comment/question... I ask this seriously, aside from causing temporary blindness to other drivers, do these aftermarket bulbs serve any purpose?
Old Apr 28, 2006 | 02:24 PM
torch red's Avatar
torch red
PMOR--please let us know how your set up goes with those bulbs and pics if u can...very interested thanks..
