TECH: Nitrous Oxide FAQ
Old Feb 8, 2007 | 02:11 AM
  #31
LAK3RS's Avatar
LAK3RS
Default RE: TECH: Nitrous Oxide FAQ
Thanks man.
But me....questions....what are you talking about..LoL. Well here it goes.
I'm thinking either Zex or N/X. One of the two. Now I do know it's gonna be a while before I do this, but it's what I think will truly best suit my performance needs for my car.
First off, before I even THINK of going Nitrous, I'ma finish up my FULL N/A Engine. That means even the usless BBK TB, Steeda Spacer, but the not soo useless Mezeire Water Pump, Battery Relocation w/new Battery, Cams ( Comp
F4.6 3V Modular XE261H-15.5 Cam Set) etc. Of course ARH 1-3/4" LT's w/ X Pipe, maybe Exhaust cutouts...I dunno yet. PH Aluminum DS, PI Torque Converter (3000-3200 Stall), Fuel Pumps (GT40), Fuel Rails (Metco), Injectors. Full Suspension, Brakes, Wheels/Tires, and thats about it.
I'm really sorry man, I just kinda wanted you to get a picture of everything.
Now here comes the Nitrous....
Now like I said, either N/X or Zex. So lets see what I need first.
- Nitrous Kit
- Bottle Pressure Gauge
- Bottle Heater
- Purge Kit
- Blowdown Kit
- Window Switch (For RPM's)
- Remote Bottle Opener (Extra)
- HTO Plugs
- Extra Bottle w/ Gauge, Heater, Blowdown, etc. (Extras as well) If expenses permit of course.
For me I wanna go ahead and throw on some gauges for precaution, as well as safety measures.
- SOS Triple Gauge Pillar
- Gauge 1 (Autometer Nitrous Pressure)
- Gauge 2 (Wide Band A/F Gauge, AEM....??)
- Gauge 3 (Autometer Fuel Pressure Gauge....??)
Well of course a control center...
- SOS Switch Panel Cupholder w/ 4 Switches
- Switch 1 (N20 ARM)
- Switch 2 (N20 PURGE)
- Switch 3 (LINE LOCK)
- Switch 4 (Not sure yet)
Well, as you can tell I've done quite a bit of research. But I'm not fully knowledgeable on the matter. So when it comes down to it, after you seeing what I have, and am planing on doing.
Which kit?
Am I missing anything?
What about that third gauge?
What TCS Window Switch should I go with?
Now, the Zex kit is around $550, and you can get the Racer Tuner Kit for $391.21 which includes bottle heater, blowdown kit, and purge kit, o yeah and the bottle gauge. That leaves me with the TCS Switch, and Remote Bottle Opener, then of course my extra stuff. So right now the Zex kit is sounding pretty sweet. Though, do I have to use their brand Window Switch? It's soooo expensive.
Now I'ma look into N/X a little bit more, but since the Zex it soo easy to install, might get it of course. Though N/X is very tempting since they are right by me.
Sorry if I went on too much, and elaborated in the subject. I'm just trying to find out all the info possible on this. Thanks man
- Justin (Yes, I spent a bazilllion hours typing this)
Old Feb 8, 2007 | 02:47 AM
  #32
FredTT's Avatar
FredTT
Haha, ok, so lets see what I can do here...
First off, thats a very impressive list of modifications. Looks like you know what you want. So let me ask you, why Nitrous? I'm pretty good with nitrous, but if your serious about power, a supercharger/turbo would be a much better way to go, and not only that, it would end up costing you less in the long run. However, if you want to do nitrous, here is what I suggest for your setup.
Zex Kit - $550
"Racer Kit" Bottle Heater. Purge Kit, Bottle Pressure Gauge, Blowdown Tube - $400
Bottle Heaters doesn't have to be from Zex. In fact, there are some cheaper ones out there that regulate the temperature automatically, which is easier.
Remote Opener - $300
TCS/RPM Switch - $150
I know its expensive, but remember, YGWYPF. Go with the Zex, better then having a different one fail on you.
HT0 Plugs - $100
FUEL PRESSURE SAFETY SWITCH - $40
THIS IS VERY IMPORTANT (hence the caps). You did not have this on your list. This is a switch that gets tapped into the fuel lines, and will save your engine if the fuel pump dies. This is to prevent grossly lean situations which WILL cause detonation. Very good safety device for the money. YOU NEED THIS!
For a Dual Bottle Setup:
Extra Bottle Plus Joints - $260
Extra Bottle Heater - $150
Extra Remote Opener - $300
Total for single bottle: $1450
Total for dual bottle: $2160
(Thats without the tune and the pizza/beer for the install )
For your gauges,
Gauge 1 should be your Fuel Pressue Gauge (this is the most important one).
Gauge 2 should be a good Wideband gauge (AEM is a good brand). Don't waste your money on narrow band stuff
Gauge 3 is up to you. Its a close call between nitrous pressure and oil pressure. You should know about nitrous pressure, especially by feel on the car (you will know when your running low), oil pressure is a little harder to tell.
For your switchs, I would recommend going in order...
Bottle Opener
Zex Arm
Zex Purge
Line Lock
I know their window switch is expensive, but its built to work with their kit, and it would be a good idea not to mix and match parts. The only parts you don't have to buy from them is the FPSS and the stuff in the "Racer kit" (although I would get a purge solenoid from them so that the colors on the kits match.)
Even though N/X is close to you, it would be cheaper to get their stuff from the net. Overall, for what your looking for, I think Zex is a good solution.
I think I answered all of your questions, if I missed something, let me know.
~Fred
Old Feb 8, 2007 | 03:04 AM
  #33
LAK3RS's Avatar
LAK3RS
First off, I'd like to say THANKS.
Yes, you answered it all perfectly, could ya give me some sites on the Fuel Pressure Safety Switch though.
Now, I honestly want 325+ through my AUTO w/4.10's and Torque Converter I might add. I do not want a TC or SC, as I just want the "Extra" Power when wanted, not all the time. Another thing is that if I ever threw on a KB S/C or PH Turbo (My choices) I would want a FULLY BUILT MOTOR TO HANDLE IT, and a coupe...LoL.
I know that by the end of summer I'll have everything done except the Nitrous. So it's still a ways away. I'm just very cautious over everything I do to my car, and I tend to ask A LOT of questions.
BTW, I love your sig. I actually have Excel Spreadsheets for all my parts, as well as "Stages" that you put as "Phases". I've finished up my basics and a little Exterior. I really apprexiate it manm thanks..
- Justin
Old Feb 8, 2007 | 03:19 AM
  #34
FredTT's Avatar
FredTT
ORIGINAL: LAK3RS
Your more then welcome. I'm glad to help.
ORIGINAL: LAK3RS
Summit Racing has alot of options...
http://store.summitracing.com/egnsea...p;autoview=sku
ORIGINAL: LAK3RS
Haha, I have the same thing. Excel Spreadsheets, with "Phases", and everything. I have every part I want to buy, type and brand, and where to get it, plus a projected price. So much to go...
Let me know if you have any other questions. If your ever in San Antonio, you can buy me lunch.
~Fred
Old Feb 8, 2007 | 03:22 AM
  #35
LAK3RS's Avatar
LAK3RS
You live in SA huh......I hate the Spurs......GO MAVS!!!!....LoL
But yeah, I might just take your "my" offer up on lunch sometime.....
BTW, you should come up to Ennis here in a little while when they open back up....[sm=nxsmile.gif] or Zex!!!!!!!!......probably not ne time soon though.
Old Feb 8, 2007 | 03:44 AM
  #36
Sprzout's Avatar
Sprzout
Anyone know if anyone has gotten a Nitrous kit that's a "hidden" kit, like the NOS "Sneeky Pete" kit? I've looked at that one, but that kit will only work with carbureted engines, so it's not gonna fly with my '07...I want to have something that's not visible when you first look, and doesn't require a huge bottle that's going to take up enormous amounts of trunk space. And I want something that I'd LIKE to think I could reverse, without having to buy a brand new intake manifold, because I had to drill holes or anything like that...
Maybe I just am wishing & hoping for something that doesn't really exist...
Old Feb 8, 2007 | 03:48 AM
  #37
blitzed589's Avatar
blitzed589
very nice post, saving this one for easy accesss on my comp.
  #38
LAK3RS's Avatar
LAK3RS
ORIGINAL: Sprzout
Zex Kit for you man!!!!!! Zex Kit for you!!!!!!!!!! www.zex.com or www.brenspeed.com
It's a very sneaky kit actually, nothing like the NOS kit your talking of though. But the bottle on the Zex Kit will be in the trunk, but that could be customized to be placed in your spare tire/jack area??? Check it out man. Look at different pics of the Zex kit.....it's very smooth and clean under the hood.
Old Feb 8, 2007 | 05:39 AM
  #39
androdz's Avatar
androdz
I ♥ Acer
You should also put about downshifting with the nitrous activated, missing gears and not power shifting if you are on nitrous. -.-.
Andrew
PS: wow you guys get nitrious hella cheap. It costs around $7 a lb here, anyway I can import a 1000lb tank -.-
Old Feb 8, 2007 | 11:29 AM
  #40
FredTT's Avatar
FredTT
ORIGINAL: Sprzout
If your looking for a small kit, (i wouldn't reccomend it because you'd have to get the bottle filled every single time you run), look at the Venom VCN-500 Recluse kit. I think thats the name. It can easily be hidden, and has a very small bottle that can be mounted almost anywhere.
As for drilling holes in your intake manifold, you don't have to do that, you drill one in the intake it's self. If you want to take it off, its nothing a little duct tape couldn't fix.
~Fred
