Camber Bolts
I'm readying my parts to lower my car & install struts & shocks ( Tokico D-Spec)
I know after install it must be re-aligned.
I will need camber bolts to do this, but how many?
Just two? one for each side in front or are there also some in back?
The link is to the bolts.
http://store.summitracing.com/partde...2+4294806411+0
How many do I need?
How many do I need?
Mine dropped just shy of 2" with the Eibach Sportlines. I was able to use the Spec-EZ camber bolts from Specialy Products to bring it back to within specifications. You should only need those two bolts, one for each front side.
The camber is non-adjustable in the back since it's a solid rear axle, so you just need two bolts for the front. I used the same Spec-EZ bolts as nbk13nw on mine and they worked well. Just make sure you read the camber of the front before you remove the struts, so you can adjust it back to normal.
Any drop of an inch or more will offset the camber by a few degrees. You probably won't notice the difference unless you plan on going auto crossing, but it will cause abnormal tire wear.
Lethaldosage423
Oct 19, 2015 12:12 AM
