Need some techie help
Old May 21, 2006 | 09:11 PM
maniac107's Avatar
maniac107
Default Need some techie help
Hiya guys. I've had my v6 2005 mustang for about a year now. Just recently i was pulling into my friends driveway and my front right wheel went over his curb. The plastic trim piece behind it get ripped off and the metal got bent a bit. Useing a dremel and some other tools i reattached the piece; BUT there is a slight crack in the plastic body right behind the wheel "on the bottom" and the screws that are supposed to help reattach the plastic body to the trim piece is missing. Any recommendations on ordering those screws?
Old May 21, 2006 | 09:35 PM
tncruiser's Avatar
tncruiser
Default RE: Need some techie help
try the dealer but first drill a tiny hole at the end of the crack that
will prevent it from spreading ,then at little glue or gib weld
Old May 21, 2006 | 09:41 PM
Stang Skeleton's Avatar
Stang Skeleton
You might want to take it to a tire/wheel shop. They weld cracks in wheels and fill and sand them all the time. It shouldnt be too expensive either. Definitely a good idea to fix that though, because stuff like that spreads especially at high speeds and on bumps etc.
Old May 21, 2006 | 09:59 PM
maniac107's Avatar
maniac107
Thanks so much guys. I'll drill that hole right now and head off to a mechanics. BTW i believe the partially cracked piece is called a rear insulator. And how large should the hole be? 1/8 an inch radius?
ucinn
Jul 23, 2015 03:12 PM
mirrormask
Sep 1, 2014 01:01 PM
CJCuster89
Mar 28, 2014 07:07 PM
ezpotato
Oct 11, 2013 08:13 AM
jlogan666
Jun 14, 2013 02:30 PM
