CDC light bar
Old May 22, 2006 | 06:06 PM
b_hollier's Avatar
b_hollier
Default CDC light bar
Does anyone know the best place to get a CDC light bar for an 06 Vert?
Old May 22, 2006 | 07:19 PM
Sean3667's Avatar
Sean3667
Default RE: CDC light bar
ORIGINAL: b_hollier
Ordered mine direct, and it showed up less than a week later.
Old May 23, 2006 | 04:27 AM
05SDI's Avatar
05SDI
OK Sean but car to tell us where you got it from? Got a link?
05SDI
ORIGINAL: Sean3667
ORIGINAL: b_hollier
Old May 23, 2006 | 11:19 AM
Sean3667's Avatar
Sean3667
http://www.classicdesignconcepts.com/
Old May 23, 2006 | 12:41 PM
b_hollier's Avatar
b_hollier
Thanks. Went ahead and ordered it with the GT 500 pedals. First time I have seen them. Does the light bar add to the body stiffnes?
Old May 23, 2006 | 12:49 PM
Sean3667's Avatar
Sean3667
ORIGINAL: b_hollier
They claim it does, but ... considering the '05-'06's were designed from the ground up with a convertible option in mind ... the average driver probably won't feel any noticeable difference.
One suggestion ... spring for the Webelectric Light Bar Switch. I ordered the "Generic" LBS-1 version (they also offer a plug 'n play harness version listed up to the '04 Mustangs, but '05-'06 compatibility may be a question), and it works great. The light bar won't light up your interior when the top is up ...
http://www.webelectricproducts.com/products.htm
Old May 23, 2006 | 02:02 PM
Tres Wright's Avatar
Tres Wright
I couldn't tell a difference in stiffness before and after installing the bar, but I wasn't expecting any. I will say the mounting setup is very solid, it probably does give some small amount of rollover protection even though it says it doesn't. But the main reason for getting one is just the coolness factor I second Sean's recommendation of the Webelectric switch, it works great!
Old May 23, 2006 | 06:23 PM
b_hollier's Avatar
b_hollier
Thanks everyone. I don't know if I need the switch. The car is driven with the top down when it is driven. The top hardly ever goes up. Down here in the south it is Vert season year round, unless it is raining. Thanks everyone for the input.
Old Oct 25, 2006 | 01:37 PM
Larmo's Avatar
Larmo
Hey guys... curious where did you mount the switch? On the dash somewhere? Pics would be great of the switch !!
Old Oct 25, 2006 | 02:31 PM
Rupp's Avatar
Rupp
Any of you guys that have this bar added the wind screen? I would think that would extented the vert season?
